I've just checked that my spare tyre is actually smaller than my original tyre. The spare tyre is 13" while my tyre is 15" size. Is it ok to use it or I need to replace it with the same size?
I have a crazy idea for my 4G93T. Can i change my 4G93T engine block with a 4G94 Mistubishi Lancer block and maybe use forged pistons and forged conrods (eagle conrods)... Btw the 4G94 engine block is made out of castmetal and the bore is 81.55mm & stroke is 95.8mm. so can i still boost high on the GSR if i use this block to replace the standard one?
Do you guys think this idea of mine will work, will there be an increase in hp?.. need feedbacks from all the turbo sifu's...
