Skunk 2 Pro Series Intake For Local K Series
powerautohauz
Skunk2 Racing’s Pro-Series Intake Manifold improves airflow thus increasing horsepower by as much as 8% over stock manifolds on stock engines and even more on modified or forced-induction engines. Our new Pro-Series design features a 22% increase in power over our previous design. Engineered with a larger plenum and tapered runners, Skunk2 manifolds increase and accelerate airflow, and are designed to increase the effects of wave scavenging at the engine’s optimum operating RPM range providing a broad overall increase in usable power. Each runner entry is also modified to balance airflow between cylinders. Over sized throttle bodies can be used as a result of the modified IAC opening on the flange. Like OEM factory manifolds, Skunk2 manifolds are shell molded and CNC machined, to achieve superior strength, high-quality finish, and a precise fit. The Skunk2 Pro-Series manifold utilizes all stock sensors and auxiliaries for a simple bolt-on installation that delivers maximum power. Ideal for NA and Forced Induction.
- Increased Mid-Range and Top-End HP and Torque
- Unique Water Neck Adapter Eliminates Cutting
- 70mm Throttle Body Bore
- Compatible With Up To 76mm Throttle Bodies
- Thermal-Insulated Gasket Included
- No Throttle Body Adapter Required
- Angled Design for K-Swap Hood Clearance
- OEM-Quality, Shell-Molded Casting
- Skunk2 Nameplate
- Vacuum-Tested for Quality
- OEM Sensor Provisions
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Operation Hours: Mon~Sat 9am~7pm
GPS: Latitude 3.067118, Longitude 101.601951
Click Here For Google MAP Location
Land Mark:
Same row with Kedai Tayar Silverstone Teck Meng, REV PERFORMANCE, Millennium, 2 shops beside SAMURAI RACING.
For serious buyer please Whatsapp or SMS
Desmond 017-396 8567
Email us : [email protected]
Dealing method : Pos/Courier everywhere in
Malaysia including Sabah, Sarawak, Brunei, Indonesia, Thailand, Singapore and all area in Asian.
