Both items are brand new. The intake manifold will only fit the B18C1 while the TB is for any series b,d and h-series.
Description as follows:
VICTOR X INTAKE MANIFOLDS - Part No 4760 and 4764
HONDA/ACURA B-SERIES MANIFOLDS Optimized for maximum power from 7,000 to 10,000 RPM, the Victor X manifold is designed for turbo and all-motor applications. Engineered for high performance, this manifold has four additional bosses for nitrous or added fuel injectors. Match with the Edelbrock 65mm throttle body for street or our Victor 70 or 75mm throttle bodies for racing applications.
HONDA/ACURA 65mm THROTTLE BODIES
Designed by Edelbrock, these direct bolt-on throttle bodies come complete with a new throttle position sensor and bore area that's 18% larger than stock for increased performance. Edelbrock street legal throttle bodies bolt directly to the stock manifold with mounts for stock sensors and vacuum lines. They are the best choice for accurately controlling airflow into the Edelbrock Performer X manifold but are also engineered to work perfectly on an OE intake. The large bore area is capable of enough airflow to supply full tilt alcohol and turbocharged drag engines making upwards of 800 HP.
Intake manifold - rm1400
65mm TB - rm950
why buy type r parts when you can get these high quality items for almost the same price. they can support up to 1000hp or any amount of boost u can throw to them.
Call me to view them 017-378 4863.
Paypal accepted!! If you don't have a Paypal account, go register it on paypal.com and tag your credit card there.
65mm TB - rm950
