Espada Motors Sdn. Bhd. is located in the heart of Bandar Sunway whereby we are operating from an industrial lot where we provide A ONE STOP SOLUTION to cater to all our customer's expectations. We are passionate about cars and we specialize in Continental, Japanese and Classic Cars. Equipped with the latest diagnostics such as BMW GT2, Star Diagnostics, Piwis 2, and others which allows us to diagnose, code and calibrate all faults accurately. Our scope of work includes engine rebuild, diagnostics, body repair/paint refinishing, suspension, interior and complete restoration.
Sicom Carbon-Ceramic Brake Kit for Nissan GTR R35 (Front) by Espada Motors
World's Lightest Brake Rotor Technology Ultra Lightweight Performance Braking Technology & High Temperature Material Applications
Ceramic brake discs are heat resistant up to 1400°C, where steel rotors can only be used up to 800°C. Due to this ceramic rotors have a much higher energy capacity and are a lot more durable under hard use. An overheated steel-rotor will curl up, the pads start to smear and the brake fluid will overheat. All of these things will cause your brakes to fade or, in the worst case, fail completely. However, with ceramic brakes you can even use racing brake pads, with very high friction value, because the additional heat is no problem for a ceramic rotor. Less weight. The weight savings of using lightweight carbon-ceramic brakes can amount up to 35kg per car. Saving up to 35kg at the brakes alone would mean a theoretical weight loss of up to 175kg at the chassis.Better Handling & Less wear.
Description:
The SICOM Carbon-Ceramic 410mm Front Kit offers a tremendous increase in the braking performance of your car. The enlarged striking surface, improvements in heat resistance and heat dissipation shorten the stopping distance and prevent brake fading, even under permanent, extreme stress.
The weight savings with this kit amounts to about 17 kg.
On the basis of the fact, that these weight savings occur at the unsprung and rotating mass, this is equivalent to about 85 kg of weight savings on the chassis.
The kit contains:
2x SICOM CC brake discs 410x42 mm
2x SICOM 4-piston brake calipers 405/40 nickel coated
2x Caliper adapters
2x Set of brake pads
Price: RM 28399.00
For other cars & models please call me.
Please drive your car to 11, Jalan PJS 7/19 46150 Bandar Sunway, Selangor for pricing & quotations. For any enquiries please feel free to call me at 0123030249.
Hope to hear from you guys soon. Thanks for the support in advance guys.
Thank You.
Contact no: 0123030249
Address: No 11, Jalan PJS 7/19 46150 Bandar Sunway, Selangor.
Description:
The kit contains:
2x Caliper adapters
Price: RM 28399.00
Thank You.
