Setting SAFC 5 Button For evo 3
rizal2105
51
Pls help me to set the safc 5 button. Behind the safc got 8 button on & off. What should put for CAR SELECT. Anyway i'm using ECU evo 3(stock) 2364.. injector 550cc.
xtremeleo
3,247
464
5,183
what u are referring to is the jumper, it determines the proper setting for a particular engine. ive been searching around but cudnt fine the proper code for ur engine sir.. will post it here once i locate it
---------- Post added at 03:26 PM ---------- 6 hour anti-bump limit - Previous post was at 03:03 PM ----------
i think ive found it sir, its 00111010 for ce9a 4g63. hope dat helps
i already complete the engine in this week,but still not perfect.boost until 0.6bar still ok but over 0.6bar the car is going worst.i need get some exp from you guys.........
