semi slick or normal tyres
KeeSeong
78
508
hi sifus,
wanted to ask wad tyre u all currently using for ur daily driven n touge car?? hehe
currently am using semi (already semi when buying tis car).. but is time to change so now headache wan to change normal or change bek semi?
so far quite satisfy with semi on dry road feeling macam ada glue stick on the road hehe but during rainy, im driving 60 haha scare spin leh...somemore duno the lifespan n they said using semi slick will bend ur car bodyframe..true ar? If yes scary leh...
Any comments from sifus r much appreciated...
KenDiriwan
1,283
225
3,163
kendiriwan.multiply.com
UHP is more than sufficient on daily and touge purpose. Using semi slick, you are not only endangering yourself but other road user. The question is are you able to pick up full responsibility on you and others when something wrong happened? You won't be thinking of going back to tyre shop as they don't held duty on where you going to use your tyre and consequences.
I believe tyre alone is less capable in bending your chassis frame unless your vehicle is fitted with track configured suspension. Keep your semi's for track day.
^pomen_GTR^
7,000 RPM
7,514
1,690
The Mines
yokohama ad08
6UE5t
6,000 RPM
6,756
1,300
hi sifus,
If you still want to have that glue-like grip while reasonably good enough in the wet and have enough budget, then can try the Yokohama AD08R like Pomen GTR mentioned above. Otherwise, like bro KenDiriwan suggested, better just use UHP or Max performance tires (like Goodyear F1, Michelin PS3 & PSS, Continental CSC5, Hankook V12 Evo2, BS Potenza RE003, etc2.) Those are already very grippy tires and excellent in the wet too.
30,002
hi sifus,
What semi slick are you using now? If near bald it is going slick already....hhahaha:rofl:
If want good in both dry and wet, go for UHP and/or Max performance tyres as mentioned by both Bro. KenDiriwan and bro. 6UE5t.
If want more dry grip then go extreme like what bro. pomen mentioned. From AD-08R, still have Federal RSRR, Toyo R-1R, GT Radial SX2, etc.
After extreme category will be your semi slick.....
KeeSeong
78
508
wokie wokiee...thanks for advise... will look for the tyres recommended.. :)
---------- Post added at 08:14 PM ---------- 6 hour anti-bump limit - Previous post was at 08:06 PM ----------
Bro.. im currently using
Front - Kumho ECSTA
Rear - Federal 595 RSR
actually 4 tyres still have grip js that rear tyres got crack on d sidewall so was planning to change 2pcs same brand.. but looks like im goin to change UHP after ur all advise.. but those tyres quite expensive mayb look for good condition 2nd hand..
6UE5t
6,000 RPM
6,756
1,300
Front - Kumho ECSTA
Bro, what sizes are you using actually? How much is your budget?
30,002
Front - Kumho ECSTA
Yup, what tyre size? If possible get new better.
Your Kumho Ecsta is what model?
KeeSeong
78
508
Just checked the tyre, mine is Ecsta XS.. year 2011..tyre size 225 45 17
budget ah.. 800 to 1000?
Friend recommend bridgestone RE003.. but definitely over budget for the size.. so looking for 2nd hand lo..
30,002
Ecsta XS is KU36, including Federal RSR means your tyres are extreme tyres, not semi slicks. Semi slicks another category up, semi have even better dry grip but lesser wet grip.
RE-003 is UHP category. Dry grip not as good as extreme but better in wet.
For RM500 per pc, try checking out PS3 and GY Asy2, both Max category, but price might be slightly over 500
If still into extreme can check out Kumho new V720 and Nankang NS2R. Too bad for Achilles 123S and GT Radial SX2 your tyre size not listed.
KeeSeong
78
508
Got extreme category ooo... but i look on website they put kumho n federal under semi slicks category n looking on the grip i reli tot it was semi slicks.
Hv u heard of tth tyre at puchong?? Tot of goin there to look for tyre mayb hv 800 to 1000 for 4pcs? Due to budget constraint :bawling:
6UE5t
6,000 RPM
6,756
1,300
Wah if only rm800-1000 for 4 pcs difficult la! Maybe just try to get Achilles ATR Sport 2 or something, maybe have your size. Some forumers here said it's pretty good value for money.
KeeSeong
78
508
HAhha...the budget is for 2nd hand wor...
If new i think i will go for UHP lo... re003
30,002
Nope, Federal website mentioned extreme performance...
Federal Tyres - UHP
Federal Semi slick is their FZ201 model
Federal Tyres - Federal Motorsports
Kumho USA only states them under UHP only, but is top of the pack. To me LE Sports is UHP, and XS and V720 are extreme category, because poor wet traction
Tire Selector - Kumho Tire USA, Inc.
Yup, heard of TTH Tyre, they are in Puchong light Industrial. Last time went there a few years ago. Old 2nd hand tyres imported in. Hard to find tyres that can pair off and that time tyres quite old so did not take any from him. You can try go and have a look, but don't buy any tyres that are too old. Rubber compound harden then less traction already.
If really on budget better off getting new Achilles ATR Sports 2, Rovelo A1 Sports. 4pcs around RM1k or slightly more can get if not mistaken
30,002
Thanks for the valuable advise bro...:proud: is time for me to decide which tyre to go for.. hehe
You can go to TTH and have a look first before deciding, maybe got luck you can find some good tyres. You can also try those bigger tyres shops, they may also hold some traded in tyres.
KeeSeong
78
508
Sure noted sifu... will go TTH try try luck first.. hehe
30,002
Let us know the results of your hunt. If in PJ, go Sunway Hup Shun and check whether got traded in or 2nd hand tyres also.
jerrysiow
407
146
1,543
Seremban
Haha, downgrade to 15" RIM and you can get decent new UHP tyres with RM1000 budget. Not sure 15" able to clear your disk rotor or not, just a suggestion.
