Japanese brand - SECTION also know as SILKROAD
Item is in working condition
Suspension come with adjustable pillow ball
Front Standard Rate/Free Length: 8K/H200
Rear Standard Rate/Free Length: 7K/H250
For further referrence, u may check out this website
Translation result for http://www.silkroad-jp.com/section/a8.html
* Executing nitriding in the piston rod, the cylinder and the outer tube. Coupled with the high pressure gas charging type mono tube shock absorber of the attenuation quality which stands up smoothly from low speed, actualizing the smooth operation where the friction is little. In addition, controlling the occurrence of aeration and cavitation even in extreme use.
* Total length pitch integral expression, it corresponds to wide setting with attenuation power 8 step adjustment.
* Strut type to make inverted system, rigidity and heat dissipation characteristic substantially rise.
* Damper, to spring and upper mount assembly conversion.
* Merit of nitriding
[Hardness = it has possessed the merit which] [abrasive resistant = superior] [corrosion-resistant = superior] [heat-resistant = superior] [deformation = small] is superior hard very much in comparison with heat treatment such as cementation or induction hardening.
interested, kindly PM or contact me at 0163900488
