rusty fuel tank, any advice ?
xtremeleo
3,247
464
5,183
i usually advice on changing it jer,but it depends on what car is it for? some cars are impossible to find its replacement. i. dat case, i wud advice differently
wongsengming
79
is a 1.6 wira fuel tank. but i haven take down the fuel tank, just inspect from the fuel tank float, the float gt rusty too, look in the fuel tank seems to have some rusty powder
you mean rusty on the outside?
outside still look nice
wsukun
695
785
1,593
London Calling
rust will spread all over eventually i assume.
better change it or risk for clogged fuel lines and other vital components.
ColdPlay
288
112
1,543
Cleaning and re-coating cost around RM1xx. Replacing with good condition halfcut tank is another option. Cost close to RM3xx.
Not sure about the cost of new tank though as most people prefer halfcut ones.
DIY is another option but problem will be finding a right coating material as the petrol itself can be corrosive.
wongsengming
79
re-coating outside surface or the tank in side? actually i would like to DIY, just need some advice, how to clean it, using what kind of method or material
ColdPlay
288
112
1,543
Re-coating required on cleaned area. Doesn't matter outside or inside. Main concern is inside as the rust may contaminate the fuel lines. Unlike outside part which can be coated with any suitable material, the inside part is quite a headache, Grinding tool is too much for small area. Maybe you can try 1000cc sandpaper just to removed the thin rust. Make sure to clean properly. Check out Ace Hardware for suitable coating material.
xtremeleo
3,247
464
5,183
if its a wira,change to a new unit. dont bother with other tedious works. u have much choices to choose from,there are a lot selling around,shudnt be too expensive imo
How to coat the inside? Cut open?
---------- Post added at 10:47 PM ---------- 6 hour anti-bump limit - Previous post was at 10:45 PM ----------
Be careful when handling fuel tank, even when empty the petrol fume can ignite and explode.
Friend kena before.....
Aiming Headlights Or, how to maximize visibility without blinding other drivers By: Tom Morr/autoMedia.com
Causes | Back To Top
Headlights can become misaligned in many ways. One of the most common is when the person replacing a bad light inadvertently turns the adjusting screws instead of the retaining fasteners. Fender-benders and other front-end damage can also cause lights to become askew, as can carrying heavy loads in the rear...
