hypergadgetstore
[WTS] 3rd Gerenation Car Door Rubber Seal (Sound Proof)
Small D-Shape Car SoundProof Rubber Seal RM5.00 Per Meter (Not Include Courier Service Fee)
Big D-Shape Car SoundProof Rubber Seal RM6.00 Per Meter (Not Include Courier Service Fee)
Big P-Shape Car SoundProof Rubber Seal RM 7.00 Per Meter (Not Include Courier Service Fee)
Minimum order 10 Meter
Let Your Car Make Low the Wind and Sound of Vibration & Dust
Soundproof Rubber Seal With 3M Tapes Introduce:
Effects:
- Increased body confined, closed the sound can be more thick, heavy feeling
- Effectively reduce wind noise, road noise, the car passed, enhance driving comfort
- But also to prevent dust and rain into the car, the applicable in the front cover seal
- Waterproof and dustproof sound effect is obvious.
- Low the Wind, Sound of Vibration & Dust
Installation:
1) On the need to install the seal and seal the site bit plane thoroughly clean and dry.
2) Selecting paste bit, find out the paste used to seal the side door after starting the bottom rod began to push a little bit of paste a little careful not to pull the seal of the action, try to keep the prototype seal slowly aligned accurately identify the Paste the path carefully paste
corner position in the frame, seal very gentle to pay attention to narrow to type, Do not bend too fast aesthetic impact.
3) Check and correct all the paste in place after the time later on after the hand for the press attention to detail is, can call it a day, and this time it is best not to close, through the open door to wait 20 minutes and then shut the door again, Then the best, etc.
3 --- 5 hours before normal use to open the door.
4) After pasting a hand to pull the seal ban, ban car washing water on 3 days (rain ah no way back) as much as possible within 24 hours not to repeatedly switch the door.
5) The construction will be a bit tight after the closing, please do not worry, in the first 2-3 days when you can normal.
6) Let us in the first 1-2 days of the time more attention to the door is not closed, safety first.
Choice of installation tips: After the installation location is closed by positive pressure seal must be in the state, so as to make it completely the role of gum.
(Note - pressure: the pressure and the gum where the direction perpendicular to the plane)
Please SMS or PM for order 019-206 6763
More Product Please Visit Our Web Page
Effects:
Installation:
