ROYAL PURPLE HIGH PERFORMANCE MAX EZ SYNTHETIC POWER STEERING FLUID with SYNERLEC
Apache91120
97
508
Klang
Royal Purple Max EZ Synthetic Power Steering Fluid is an advanced power steering fluid designed to maximize the life and performance of all power steering units. Max EZ is formulated with a blend of select synthetic base oils plus Royal Purple’s proprietary Synerlec additive technology, which is proven to make equipment run cooler, smoother, longer, quieter and more efficiently. Max EZ is compatible and can be mixed with conventional power steering fluids and has excellent seal compatibility.
Performance Advantages:
Greater wear protection
Clean, efficient equipment
Extended pump life
Much longer fluid life
Non-foaming
Outstanding rust / corrosion protection
High temperature service capability
MADE IN USA
TEL: 012-9154001
Hey guys..Im having abit of problems searching for my perdana short shift la...can any here help me out..??
can a wira short shift goes into a perdana...looks the same...advice me on this...thanks
