Engine spec:
CM5A 4G93 T Engine (JPJ Approved & Endorsed)
fully rebuilt engine
wiseco pistons 1mm oversize
clevite engine and conrod bearing
H-beam duratec conrod
1mm steel headgasket (ori)
ARP head studs
ARP conrod bolts
Engine fully balanced at 10,000 rpm
Torque Gear Full Exhaust System (Stainless Steel Straight Flow) With Titanium Tip & Thermo wrapped from dump pipe towards Mid-Section
Torque Gear Custom Intercooler Piping, & Air Filter Adapter
Tonnka Extractor
TD05-20G
Steel Braided Hose For Turbo Oil Line
Tail Wastegate (Ori)
Tail Blow Off Valve (Ori)
Evo6 Intercooler
Forged Racing Full Aluminium Radiator
Evo6 Stock Fan + Hi-Speed 12" Slim Radiator Fan
Battery Relocation To Rear (High Quality Cables)
Bosch Battery
Harden Engine Mount (Full Polyuthrane Bush)
NGK Iridium IX Spark Plugs
Works Engineering Fuel Regulator
Works Engineering Fuel Rail
ID 1050CC Injectors
walbro 255LPH Fuel Pump (In Tank Fuel Pump)
SARD Oil Catch Tank
Evo 6 Throttle Body
12PA Denso Aircon Compressor With all custom piping
R3 Aluminium Brake Reservoir Cover
R3 Aluminium Clutch Reservoir Cover
Transmission:
Excedy Evo6 Clutch Cover
Racing 4 Puck clutch Plate & Bearing
Fully Skimmed & Balanced Flywheel
Custom Clutch Resevoir Steel Braided Hose
Custom Independant Clutch Reservoir
Evo 6 front LSD (I also have another spare LSD will give to new owner)
Chassis & Suspension:
R3 Bump-Steer Kit
GAB SS Series Coil Over (Front 6kg Rear 4kg)
GAB Pillow Ball Mount
GAB Rear Strut Extender Knob
Zenden Front & Rear Strut Bar
Arospeed Room Bar
Eibach Anti Roll Bar 22mm (Front) & 16mm (Rear)
Custom Anti-Roll Bar End Links
Brakes, Wheels & Tyres:
Evo 3 brake calipers with custom brackets
Endless high temp Brake Pads (Front & Rear)
AXT Slotted Rear Rotors
evo 3 Stock Front Rotors
Pro-RS Steel Braided Brake Lines
Buddy Club P1 Racing 15 x 7.0JJ, 4 x 114.3, +38 Offset Wheels
Enkei Wheel Valve's
Toyo R888 semi slick tyre 205/50 R15
Electronics:
AEM Tru-Boost (Boost Meter + Boost Controller All In 1)
Adaptronic E420C Standalone ECU
Launch control, Anti lag activated by switch
Sound system:
JVC Radio Player
Alpine 300W speakers all round (very loud)
Kenwood 1000W subwoofer
Kenwood 640W amplifier
Kenwood 350W amplifier
Interior:
CPS High Line Door Panels
Under Chassis Carpet Changed To CPS Grey Color (Ori From Proton Part Centre)
SSCUS Star PVC Seats (Pair) & Custom Seat Rails
Sabelt 3 Point Harness (Pair & Original) (2Set)
Ralli Art Gear Knob
R3 Carpets (Ori)
3M Crystalline Automotive Tinting
Momo Replica Steering
R3 Spacer 45mm
NRG Quick Release (CF Type)
Exterior:
R3 Full Body Kit (Ori)
R3 Front & Rear Emblem (Ori)
R3 Number Plate Holder (Ori)
Racecraft Carbon Fiber Hood
Aerocatch Hood Lock (Ori, not the replica's sold over in msia)
Lubricants:
AMSOIL 10-40 Engine Fluid
Motul Gear 300 75W-90 Fluid
Motul 90-PA Transfer Case Fluid
Motul DOT 5.1 Brake & Clutch Fluid
Motul Coolant
Shell Power Steering Fluid
Additional Information:
Spend almost 40k-50k on the car or maybe more lolz....there's much more things but sorry some of the stuff i might not remember view the car yourself if interested....
Previously tuned and dyno by me approx 400hp at 1.5 bar boost
As I am a tuner, I can teach the new owner how to tune the ECU on the dyno (FOC)
Reason For Sale:
I am leaving Malaysia, so i Hoping to find another enthusiast to take care of my precious ride >.<
Contact:
Mood
Call or sms 01112821421
or whatsapp +96899389293 (if cannot get me on malaysia number)
keywords: Gen2, gsr, turbo, GTR, 1jz, 2jz, evo, drift, STI, civic, B16, b18, b20, tial, race, gsr
Read more at Proton Gen2 (M) - Cars for sale in Bandar Sunway, Selangor
ARP head studs
ARP conrod bolts
Tonnka Extractor
TD05-20G
Evo6 Intercooler
Bosch Battery
ID 1050CC Injectors
SARD Oil Catch Tank
Evo 6 Throttle Body
Transmission:
R3 Bump-Steer Kit
Arospeed Room Bar
Enkei Wheel Valve's
Electronics:
Sound system:
JVC Radio Player
Interior:
Ralli Art Gear Knob
R3 Carpets (Ori)
R3 Spacer 45mm
Exterior:
Lubricants:
Motul Coolant
Reason For Sale:
Contact:
Mood
