Proton 4G13/4G15....Satria/Wira/Saga
Bro,
Tolong tunjuk ajar sikit. 1.6 stroker kit, taken from what car? berapa harga? siapa ada jual? second hand punya ada?
How much the stoker kit stuff cost? I already in the midst getting twin Webber for my 4g15 liao. oh yeah!
most of the stroker kit (can say all) are second hand stuff.... crankshaft can hardly get brand new ones... pistons and conrods still can.... but recommended to get used ones as they are seasoned already....
price around 1.5k for the stroker kit alone... powerzone selling for 2k for the stroker kit....
stroker kit taken from 4g18.... 1st batch waja engine (non campro).....
Which Mitsubitsu Colt? new one or the old one?
new one lor...
some w/shop here qoute RM 1700 for doing this cutting plus balancing together with pnp.Is this a good price?
if u really plans to do it, invest more in a good reputated workshop to do it perfectly for u.... imbalance crankshaft can send u scouting for new engine....
remember to do full engine balancing (piston, conrods blueprint... flywheel, crankpulley, crankshaft balancing) for better effect....
If really all these can be done well, I mean fitting the 4g18 stroker kit, with good light crank pulley, twin webber, 4-2-1 manifold, how much agak agak hp can be extract? compare to original?
But, still if I'm using the old 3 speed auto gear box, also, no much different, right?
So, any recomendation of changing 4 speed auto gear box?
wow! the stroker kit alone cost RM 1.5 - 2k. Really need to think twice + 2-3 time before buying.
I just wonder, if i saw one Waja, the waja caught fire, the whole car now just left the burnt engine+body, don't know the stroker kit can be taken out and used? If can , haha, maybe, I can have the set for < RM 200. :nurse: I will dismantle the engine myself. Very challenging, just don't know worth to do this or not.
it is not as cheap as u think.. once u start.. u will need to spend on other stuff like the top gasket kit, bottom gasket kit, all wear n tear parts, beltings, water pump, hoses. etc etc... which would easily touch rm4-5k...
Only 1 way to find out, do it bro
Bro maybe you can come down to PG after this raya.You can discuss with the mechanic here.He qoute me rm1800 including workmanship because my engine is 4g13,i'm sure you can get less than that.Because you dont have to punch the engine no. which will cost you rm200+ and you also dont need to look for 4g15 block which is pretty expensive nowdays.Maybe you can do the knife edge cutting crankshaft & full balancing as well.:biggrin:
yeap.... u need to prepare extra for reboring ur block... new conrods bearings... new piston rings... new crankshaft bearing and so on.... its more or less like full overhaul engine...
lolz... how often u see a burning waja 4g18 on the road??... if yes, will the owner allow u to pull the engine out??... and how would u bring it home??...
Wow....nice info from you all....Selamat Hari Raya from me....ehehheheheh
Drive safely....and fastly...:biggrin:
heheh... 2 days ago went back hometown... was cruising about 160kmh for more than 30minutes behind an Alphard without much problem n effort... hehehe...
yo brader, back in melaka adi??...
hmm... later go out also must becareful adi... lately many powerful cars come back melaka... cipan also in melaka for raya....
there is one more thing too, change ur flywheel to super touring , not 1.6 ar....., try to find 8.5inch... , is difficult to get la..
y wud u want to put more load on the engine?
bigger = harder to spin
heavier = harder to spin
bigger but same weight as ori flywheel = still harder to spin
i could only see one case which would warrant the use of a larger flywheel; a heavily modded engine which needs a larger racing clutch to cope with its output...assuming u dont want to mod the ori flywheel to put a larger clutch for ur own reasons, durability ka etc. etc.
just my 2 sen
just my 2 sen
erm.... sifoo... lets say gt 2 choice...
1) 1.3/1.5 exedy 3puck racing clutch (that rm550)... can use back ori flywheel dont need to mod....
2) 1.6 or 1.8 standard exedy clutch... include modding flywheel around rm3xx approaching rm400... but according to users, it will still lose grip when overheats... definitely better than standard 1.3 clutch lar....
which one to choose??... i got dilemma... :(
mana sifoo :P
if i were u, the option i would take is the first one, plus a little more: exedy 3 puck clutch for 4g15, and a slightly lightened and balanced flywheel...
OR get a slightly larger flywheel so u can use a larger 1.6 racing clutch...if u wanna use standard 1.6/1.8 clutch, like u sed, during enthusiastic driving it will lose grip, dun 4get it is still an oem clutch designed more for comfort than anything else, of kos still better than standard 1.3 clutch la
ur engine modded lots edi...no more standard
the 1.5 3 puck clutch is nice, pedal pressure is acceptable, and it bites...after 1-2 months of using it, with lots of enthusiastic driving, no slips at all, just that the initial 'juddering' upon take off, is less, not sure whether this is a sign of the clutch settling in or what :P
i like the idea of using back ori flywheel la, lighten a bit, engine more rev-happy...
Hi ,
May i interrupt? hehe
just want to ask... let say whenever im at low rpm during any gear, i will feel juddering in my engine bay.. is this a sign my clutch worn out? FIY my car is near 3 years old and reaching 100k soon..
is rm550 for 3 puck clutch include installation? how much for the oem including installation?
mana sifoo :P
now my flywheel is slightly lightened already... my mech said my engine setup is for pickup due to lightened flywheel... datz why i having hard time touching 180kmh....
since my oem flywheel already done lightening, its better i get the exedy 3puck racing clutch, plug and play into my car??...
its tempting to use racing clutch.... but the price makes my decision more complicated...
Hi ,
yes.... clutch should be replaced around 80,000km... around same time with ur timing belt... if u feel judder/vibration from ur clutch pedal during initial pickup, its a sign of slipping clutch....
rm550 is jz the price alone without installation... for installation prepare about rm100....
vibration I thought was engine mounting? At that age sommore.
