- Joined
- Oct 28, 2004
- Messages
- 361
- Points
- 3,018
me car feel much more lighter n much more padat..........
easy pickups...........
I am using this engine 4G93 DOHC NA on a CB Lancer and matched with a tranny from my old 4G13 engine...ECU is MMC 6123 ..I am not sure from what mitsu is this engine and ecu...
I am having no problem with the engine...it runs well and is fuel effecient, even better in fuel consumption (when used with 4G91 ECU 5660) compare to my old carb 4G13...but idle is erratic with 5669 ECU...
When I use 6123 ECU, fuel is little higher but almost neglegible. Idle is good and consistent too even with the AC on...power and torque are good, though i do not race this engine...
That putra stock also?
Zth members from Manila....So are u stay in Manila? Where do u get that engine? How about the wiring? Actually this engine is ok.But if compare with our national car model Satria GTi or Putra also using same block 4g93 dohc n/a, this 6123 4g93 got less power than our Malaysian car model 4g93p.Satria GTi using ecu code 2468 if i am not mistaken.The compression ratio also different.
haha..yup i am in manila but i usually login to this forum for more info...
it's good you have plently of 4G9 parts...can you PM a qoute for a good working condition 5537 ECU plus shipping...I was looking at FedEx site for a possible pricing for next day package, i think its manageable..if we can get through maybe I can also buy other parts online through you of course... :)
and perhaps my other friends from our own auto enthusiast group here can also transact wtih you
spors, are u cannot find 5537 ecu in manila?
Why not to try with 7737 or 5663 ecu from gsr? I found your post that u say 4g93 dohc running well with 6123 ecu. I am interested to know why u tap the injector for the wiring? Are u using 4g91 wiring?it's difficult to find 5537 ECU here...but i found some 5660 (4G91 DOCH) and 6123 (4G93 doch)...that's why im using this ECU....
Hhmmmm.... confused liao !!!
...I did the wiring for this engine. At first i was using the 5660 (4G91 dohc) ecu because I cannot find a 5537 Ecu. When I found the 6123...i had to rewire the injectors, otherwise, the engine runs with wild vibrations because the 2 injectors (2 & 4) won't be firing...the rest of the wires is the same with th 4G9X dohc...
isn't it that 7737 and 5663 for 4G93 dohc with turbo?
Yes spors both for gsr turbo but still can use with 4g93 n/a.But the fuel consumption will be little bit higher. So do u mean 4g91 and 4g93 wiring is same?
Similar threads | |
