Problem starting car. Car won't crank up.
BtLeJuiCe
123
Anyone know what is the problem if a car won't crank up? My Civic '96 EFi (Manual) can't start at times. When I insert the key and crank it up, it will not crank. It just go.. "karak".. and nothing happened. I can still on my aircond and lock my car (central locking) which means battery still working right?
Anyone had the same problem? OR anyone know what can be the problem?
kschu
439
Kota Kinabalu,
xanga.com
no krak krak krak ? either battery weak or ur starter probs or ur ignition coil prob.....hehehe
BtLeJuiCe
123
Battery
Hey!
Thanks for the reply, I've fixed it. It was the battery. Thanks peepz!
Grown up BRZ now makes 231ps / 279nm from brand new NA 2.4L flat-4. It retains the front engine RWD configuration but the coupe body has been further lightened, also tightened, with a 50% increase in overall rigidity while boasting a lower centre of gravity.
The chassis has been retuned as well, with a wider rear track and reinforced suspension mounting points. The launch model feature 18"...
