Preferences..please discuss
crazykatak
776
48
Subang Jaya
Your choice of :
engine oil
brake pads / fluid ( aftermarket / OEM )
absorber + spring ( aftermarket / OEM )
air filter + open pod / closed pod / drop in / short ram / long ram / OEM
crank pulley ( aftermarket / OEM )
cam gears ( aftermarket / OEM )
fuel regulator
high tension cables ( spark plug cables )
intake manifold
exhaust manifold ( extractor ) type
wiper blade / rubber
wheels + tyres
Please discuss :smokin:
neohadri
200
34
u makin survey becoz u want open shop or what :wavey:
engine oil - pertonas 800 semi ( would love if liqu moly can be easily found as any other engine oil)
brake pads / fluid ( aftermarket / OEM ) - 800° RS pads & Bosch DOT5.1
absorber + spring ( aftermarket / OEM ) - stock APM/KYB
air filter + open pod / closed pod / drop in / short ram / long ram / OEM- stock OEM
crank pulley ( aftermarket / OEM )- stock OEM
cam gears ( aftermarket / OEM ) -stock OEM
fuel regulator -stock OEM
high tension cables ( spark plug cables ) -stock OEM
intake manifold -stock OEM
exhaust manifold ( extractor ) type- 4-2-1 stainless steel
wiper blade / rubber - Bosch bladeless
wheels + tyres - 16", 7.0" +40 rims + S1 evo 205/45 tires
crazykatak
776
48
Subang Jaya
mana ada. just making a quick survey, to see the current trend..
engine oil - Mobil Super2000
brake pads / fluid ( aftermarket / OEM ) - Frt & Rr Bendix Metal King, Bosch Dot4
absorber + spring ( aftermarket / OEM ) - Gab HA series
air filter + open pod / closed pod / drop in / short ram / long ram / OEM - OEM R3
crank pulley ( aftermarket / OEM ) - OEM
cam gears ( aftermarket / OEM ) - Works
fuel regulator - Works
high tension cables ( spark plug cables ) - R3
intake manifold - OEM
exhaust manifold ( extractor ) type - 4-2-1 ayam brand
wiper blade / rubber - OEM
wheels + tyres - RE001 205/50/R15; wheel Et +35
FISHL
Nov 12, 2011
6
engine oil = Idemitsu Fully - 5w40 - Extreme touring
brake pads / fluid ( aftermarket / OEM ) Rapidstop front and rear
absorber + spring ( aftermarket / OEM ) Still a virgin *shy*
air filter + open pod / closed pod / drop in / short ram / long ram / OEM Long ram + Blitz
crank pulley ( aftermarket / OEM ) Stock Still
cam gears ( aftermarket / OEM ) Works
fuel regulator Works
high tension cables ( spark plug cables ) R3
intake manifold Stock
exhaust manifold ( extractor ) type - 421 SuperStreet + Custom Mid + R3 Muffler/Greddy Trust
wiper blade / rubber - MADE IN CHINA
wheels + tyres - SSR Type F + Hankook Ventus V12
ecal echal
74
16
508
hi there...
engine oil - Motul Turbolight
brake pads / fluid ( aftermarket / OEM ) - Frt Bendix Metal King, Bosch Dot4
absorber + spring ( aftermarket / OEM ) - OEM/R3 spring
air filter + open pod / closed pod / drop in / short ram / long ram / OEM - OEM + simota drop in
crank pulley ( aftermarket / OEM ) - Dori's
fuel regulator - arospeed
high tension cables ( spark plug cables ) - OEM
wheels + tyres - Taiwan Advan + ori rubber 15"
denden4
Nov 30, 2011
15
503
Johor Bahru
what is the best brake pad ? mine need to replace already
might want to change to perfomance one ..
bendix ? how much does it cost for front and rear ?
crazykatak
776
48
Subang Jaya
the OEM plugs are good enough for daily use; unless your engine is heavily modified.
another option is Denso's Iridium plugs.
just becareful of imitation spark plugs out there..
I want to find out ways that can remove or reduce the swirl marks on the bonnet of my car, they are like spider webs and can be seen under the lights or under the sun also, if you guys have tried wax or other stuffs that have successfully reduce or at least "cover" the swirl marks to let it become not visible, let me know yea? appreciate it.
