Power Steering Problem....Pls help!
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
Recently my power steering hose was leaking...
My mechanic dismantle the hose and sent for re-machining a new hose...
Thought my problem was over... but unfortunately not yet...
Another section of the hose leak again, there was a long part, and and a shorter part of the hose.
In between the sections there was I think a pressure valve...
After re-machining the shorter hose, then I thought my problem is solved, but again no!
This time, when the power steering fliud is being poured, the power steering runs very silently and
perfectly...
But after 5 minutes or so, the humming noise and the power steering pump became noisy again as before...:mad::rofl:
Can anyone experienced this before tell what could be the cause?
Or can anyone suggest what are the causes?
Please help! Thanks...:confused::itsme:
What car? Your old banger or something else?
Out of curiousity what is your profession?
Your power steering hoses need machining? I know air con hoses needs that, and my ride power steering hoses are just normal hoses secure with clips....:hmmmm:
let's wait for the TS to reply on car model. Maybe it's one of those cars with those brass metal hoses. Or he means those metal tubes on the steering rack. Or something else.
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
Maybe mercedes's hose different? Ya waiting for TS to come back to the thread.
LesleyAprotto
Banned
1,339
287
683
Its rubber hose which can withstand high pressure fliud flow..
The model is W211
The hose is at the bottom of the front below the radiator..
What do you guys think could be the cause?
The steering also is a bit heavier at times...
Could it be the fluid not flowing to the pump, could the pressure valve be clogged with dirt?
In that case I don't understand what your mech did when he "machined" the hose?
heavier steering could be attributed to wheel alignment, tyre, power steering rack, erm.. tierod - is that what it's called? Forgot what that thing is connecting your power steering rack to the wheels. Clogged valve is possible but the power steering system is an enclosed system, meaning it's not exposed to dirt or air. If your power steering fluid is regularly changed and it's still dirty, then it's very likely the power steering rack oil seals are kaput and you're getting a leak there somewhere.
Yup, is called tie-rod end.
Bro. Les,
Heavy steering can also be pump having problem, belt driving the pump is loose/slipping.
Steering fluid usually does not get dirty. Mine after years of use, only changed because hose leak only..
g88
3,081
54
perfectly...
Sound like your power steering pump and rack need to be check also aside from hose
LesleyAprotto
Banned
1,339
287
683
Today I found out that my hose still leaks!
WTF !
Probably it could be a sabo job!
Either by my mechanic or the machine shop person!
Since there is a leak, the pressure is not enough for the fluid to force into the pump thereby its noisy.
Spent the following on this stupid hose...
Machining of hose RM100 X 2 times................................RM200
Labour of dismantle & fixing of hose RM40 X 2 times........ RM 80
Power steering fliud (actually its ATF) RM10 X 2 times.......RM 20
TOTAL SPENT..............................................................RM 300
And loss hours waiting 4 hours X 2 ....8 hours!
Do you think I should go for the 3rd machining of the hose?
If I were to buy a second hand (potong kereta hose) I think it would be cheaper and less time consuming!
WTF dirty tactics by either the mechanic or the machine shop!
Anyone please advice me the next course of action....
Feel like go and burn the asshole shops!
If the newly machined hose leaks, isn't that covered by your mechanic or machine shop? Is brand new mah!, unless you have used a few months already then cannot claim...
LesleyAprotto
Banned
1,339
287
683
Already called to inform my mechanic...
Not free to go and sit there for 4 hours...
Will find out what guarantee they give me only when I see them!
Even they do it for free the machining, still I got to bear the labour and ATF cost!
WTF ! ?:banghead:
LesleyAprotto
Banned
1,339
287
683
please elaborate on "Machining of hose"...
Machining of hose is whereby the leaking portion of the hose is being replaced with new hose...
The process of machining of hose is done by using the high pressure clipping of both end of the new portion of that particular hose.
The clipping is done using metal clippers both both ends...
Similar threads   Forum
Looking For
The MR2 MRS Club
  Similar Threads
Looking For
The MR2 MRS Club
Hi sifus out there,
Recently I just got HWL hi-low soft-hard for my car (about 8 hours ago to be exact :) ), but the problem that keep bothering me all night long is about height adjustment for this thing. Since I wanted to set the car little high, the taukeh used to compress the coil spring to archive that, and for what I understand, height adjustment for this type of absorber is only to adjusting the body shift housing (cylinder body housing) and not to compress the spring. It will...
