Pls recommend good Double Din HU with GPS/MP3/USB etc funtions/good setup for wag
kayy
453
Hi,
kindly recommend a good double din player with touch screen with GPS/MP3/USB/CD/DVD functions regardless of Japan/Taiwan origin based on your experience
also kindly suggest a good setup for wagon type car.
for current setup is OEM component on front door enclosure and mid bass at rear door enclosure
subwoofer box installation is not in the picture as space is essential..active subwoofer is optional
Zenn
2,799
43
1,648
get either alpine/kenwood/pioneer, should be around 4-5k
get component sets for both front and rear and an active sub
markblurberry
115
20
518
Yeah, guess u can't runaway from these brands, they r the giant brand name in automotive industry. But for rebels who wanted something different, can try the following- akai, Blaupunkt, and philips. Installed philips in my car, so far so good n not bad at all, price is reasonable. For sound system, can try cadence, which is a new brand, the product line impress me, or can go for the mainstream brand names such as sound stream, Mohawk, etc etc...just my two cents
kayy
453
thanks for the info
as for the item mentioned, any combination series come in mind?
referring to combinations of HU+component+midbass+active subwoofer
as for active subwoofer, what will drive it?
is it directly powered by the HU(as the subs itself have a built in amp)?
Zenn
2,799
43
1,648
what do u mean combinations? recommend brand & model is it? whats your budget?
yes active sub has built in amp
markblurberry
115
20
518
hi kayy,
the combination is quite subjective, depend on your preference, but as with all audio setup it is a bit difficult to get the perfect sound you want with the first go, becos u can install then decide, u must buy 1st!! usually i would recommend, HU + component set (front) and 2 or 3 ways speaker at the back then finished off with a woofer at the back or an active woofer under the seat...depend on other requirements-u may include crossover or amps, etc..but as a general rule of thumb, always make sure the sound comes from the "front" - like sitting in a cinema where the sound is always coming from the front..and not from behind..
kayy
453
ok noted..
as for brands/model, im just curious on the double din HU with multiple functions (GPS/MP3/USB/CD/DVD/Ipod/BT) and active subwoofer as i never use these hardware during previous setups
additional :
if want to amplify, add more balance and clarity to the sound produced by all the speakers(components fronts, midbass rear and active subwoofer)..does an additional amplifier and electronic crossover needed or the power from the double din (50Wx4) sufficient?
Zenn
2,799
43
1,648
actual power from head unit is probly around 12-15W rms only, so if u want better quality u will need an amp, especially if your changing your speakers to components. electronic xover will not be needed at this stage, as u can use the low pass filters in the player or on the amp..
AD_EG
6,000 RPM
6,328
231
Ipoh
guys those pioneer models are ok right?
Pioneer AVH4350 - something like this?
im not a hardcore ice addict but i need good sound to listen to my music..for wagon...that doesnt use those 6x9 speakers, just use 6.5" midbass speakers / component set is sufficient ?
Zenn
2,799
43
1,648
even 6x9 also can. only component sets u will most probly need amps. comp set are where tweeter and midrange come separately as well as a small box called passive crossovers.
AD_EG
6,000 RPM
6,328
231
Ipoh
hi bro zenn,
my car the rear speakers are mounted on the door. so i need to maintain that setup..
a HU like Pioneer AVH4350 would not be good enough to drive those component sets?
for now i have my oem panasonic double din player on the car... and rainbow component set.
now i thought wanna get a 2way speaker for the back door... the one that has midbass and a tweeter mounted... i need good sound quality and nice supporting bass...don need those hardcore boom boom sound...but good bass for my trance music.
will this setup work?
hi bro zenn,
You're better off getting an underseat subwoofer rather than replacing the back speakers. Those have pretty pathetic bass. Even the average underseat active subwoofer is better than that. You'll probably spend almost the same amount anyway.
Zenn
2,799
43
1,648
agreed...
mughal90
364
6
kota kinabalu
Components or coaxials will never give u an enjoyable bass, initially u will like it cz they'll be better sounding from the OEM but u will miss the bass part. Best solution is use front components and a 12 inch sub in rear with a sealed 0.75 inch MDF enclosure 1.25 cubic feet internal volume lined with polyfill and run them on a branded 4 channel amp. U won't be needing anything after that :) 4350 is a very good HU for starters.
If u want pure sound quality, go for original focal polyglass V30 components. For sub i recommend infinity 1260W 12 inch SQ sub. For a 4 channel amp go for soundstream reference series. This will make an ultimate SQ setup for your car.
Made a few calls around n found out eventhough reduce cc oso hav to obtain the surat kawal selia!!! Last time i asked a Puspakom official n he mentioned no need. juz hav to bring the chop shop receipt, grant, ap n 40 bucks....
now apparently if change engine besides the original eventhough within the -/+25% cc difference must hav tt letter!! can some1 share ur knowledge b4 i approach the jpj/puspakom fellas...... :unsure:
scared the runners wanna pull a fast 1!!! thanx a lot guys!!
