overheating...
cush86
44
8
508
my bot also same issue, 11.5-12afr during boost,14 off. when boost comes on,water T jumps from 90-100/105.when driven reallly really slow,it stays at 85-90. i changed thermostat and the thermo switch for mine already. wondering wats the problem. have u solved your issue? my mech asked to add another radiator fan to solve this.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
bigger radiator needed maybe? :adore:
cush86
44
8
508
before this i boost .35 bar also no overheat,after installed individual bosch coils and lt10's now overheating(.35 bar also). wondering wats causing it. normal driving it doesnt go past 95 degree.but 95 still high for water temp.used to be 90 and below.once i boost,it climbs up pretty fast. and theres a small rattling sound in the engine bay.not sure... seems like the rattling sound n boost seems to cause the spike in water T. any other ideas as to wat couldve caused it?
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
sounds like pinging/knocking a bit to me....
maybe re-tune the ignition to retard a bit can help solve this... :adore:
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
hrmm will take a look into that. wat u think regarding the water temp?
IMHO it is from the same cause...
(if there's nothing changed since that) :adore:
cush86
44
8
508
k bro,will check both that n radi. thanks for feedback.
---------- Post added at 01:37 PM ---------- 6 hour anti-bump limit - Previous post was at 11:03 AM ----------
checked,i think ur right,just retarded the ignition for different temp maps.running fine now kekeke:D thanks pomen:)
hi guys..my side window glass got few lines of scratches due to window bracket :(.. i've heard there's one chemical/solution/liquid tht can recover these scracth marks..anyone heard of it? where can i get those?
thanks a bunch!
cheers!
