87mm can be using sr20 piston , lagi is high compression piston .. lightnen your piston and dont ball the top part , lightnen your conrod , crankshaft to pull your torque and your boost to come even u can skim your flywheel..=D .. the torque respond faster than your block do ..~ keke~
compression u want to skim your head is not good enough, sooner or later if u want to go for high cam ..man~ u will sick of it..cause u have not place for high cam~ , anyway vr4 compression is not that high .. u dont worry man~..it build with not high compression also~ just boost to make it fast ..lightening crank , conrod , piston , flywheel , fuel regulator (make your fuel shoot more inner) explosion nicer ) , air injection to pump air into .. ori ecu is abit hard to stand ..but if u got for better gear ratio nor u have a better ecu .. slightly increase torque and horsepower at least 20-40..i think~but effect torque more..highcam in a same time .with cam spoket i think u change a standalone ecu with evo3 turbine also can go more than 300-350 hbps in between easily..im a vr4 user
