need help, kancil wondering..
scoupe
1,087
37
5,148
shah alam
hey guys i need help.. i have tried so much but cant solve the problem of my car wondering.. at about 80km/h the car gets uncontrollable.. it steers with the road camber.. i have changed the lower arm on both sides, steering bush, antirollbar bush, subframe bush, all new absorbers and also tried swapping drive shafts.. the problem symptoms have reduce but its still there.. anyone else have face this problem?
---------- Post added at 11:36 AM ---------- 6 hour anti-bump limit - Previous post was at 11:35 AM ----------
owh i forgot to mention my kancil is a standard 850 manual face lift version.. alignment done too and no swelling on tires.
xtremeleo
3,247
464
5,183
is dis still the problem u pm-ed me about not so long ago sir? i tot uve rectified it..
scoupe
1,087
37
5,148
shah alam
hahaha yea man.. hmmm when are u free to test drive it? i dun drive the car at all now cause its kinda dangerous..
xtremeleo
3,247
464
5,183
ohhh, err.. iam gonna be free starting dis thursday, i can go and fetch the car for testing and perhaps continue to rectify the problem?
xtremeleo
3,247
464
5,183
possible jugek tu, but since he has done and check so much, i strongly think d steering rack was once of the first checked, kan scoupe? like i said in our previous pm, one needs to check it first hand before concluding anything because uve either checked or changed most things one can think of..
^pomen_GTR^
7,000 RPM
7,514
1,690
The Mines
tie-rod end maybe??
how old was that kancil?
scoupe
1,087
37
5,148
shah alam
hey xtremelo, maybe we can meet up at my workshop on thurs about 7.30pm? its mind boggling.. well the rack seems ok.. but havent tried changing another one, as it is the most expensive item.. tie rod end has no free play.. well the kancil is a 2006 model but has bout 200k km on the clock..
^pomen_GTR^
7,000 RPM
7,514
1,690
The Mines
alignment and camber checked or not?
I want to find out ways that can remove or reduce the swirl marks on the bonnet of my car, they are like spider webs and can be seen under the lights or under the sun also, if you guys have tried wax or other stuffs that have successfully reduce or at least "cover" the swirl marks to let it become not visible, let me know yea? appreciate it.
