- Joined
- Oct 28, 2004
- Messages
- 361
- Points
- 3,018
here the list that i modd....
- port n polish only did the intake manifold(80%) didnt touch the exhaust manifold..
- skimmed the valve a bit
- carb change the jettin choke/minjet, fine tuning havent rebore it
- modd the flywheel use 1.5 flywheel but modd it to fit 1.6 clutch plate and i skimmed a bit the flywheel
- extractor 4-2-1 wit 2 inchies piping exhaust....
- air filter remain stock standard...
- rim standard stock
- double layer brake servo 4 better braking....
- playin around wit the marking on the campulley
full modds that i havent done yet...
change piston to bigger piston 1.6 should be ok or kembara or u can try ford tx3 piston, lighten conrod, crankshaft, balance the engine/ blueprinting, hicam ( depends on the lobes u want), twin weber, most importantlly when playin ALWAYS FINE TUNE UR CARB....
