myvi with sport spring problem
Geon323
522
Klang
currently my car install 15" sport rim and lowering spring and found out that especially on the rear suspension will serious dropping when the car with fully loaded.:cry_smile:
i have do some research on the web and i found this product online, taiwan made it call rubber spring anyone here know where can i get this product or anyone know is this product useful? here is the link: http://www.toonew2000.com.tw
Excalibur
732
NoWay2Run
What lower spring are you using??? my cousin myvi with 16" rim and kenari lower spring wont have serious dropping when the car with fully loaded...
Sorry cant help you out that one....
na_power
1,412
cannot help u... u can refer to myviclub.com or myvi.com.my maybe got sumone have same experience with u know how to settle it...
Geon323
522
Klang
i using local sport spring and the brand i can't recall.... yaa i already post a similiar topic at myvi forum liao but donno the sifu there can help or not:retarded:
Fluffy
3,870
>>klang<<
erm...a cheap spring wont give u good performance la...
i suggest u get a good brand spring..
but arh...if there's more than 2 ppl at the back...if it drops..then it might not be the spring's fault..coz..2 ppl is the optimum amount off ppl..
gavan
1,408
Shah Alam
maybe your people at the back is "big" ppeopple leh? sit in any car alos sure got drop marr rite? no offence tho..but its true....
Fluffy
3,870
>>klang<<
yeah...that could be a factor..obviously putting too many ppl at the back will make ur car lower at the back to matter wat springs u use.
SkYwAlKeR
10,139
300
ePoh ~ malacca
haha... kesian dat fella lar... he asking question here and u all load satu kampung inside his car....
mayb the sport springs he bought is soft type leh... trying changing to harder absorber to reduce sagging lo.... if not, change to harder springs...
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
Hie bro, the spring plays a great role. If it's a cheap spring, the slope of the graph is low hence if load is exerted, the spring tends to compress more. Some coil springs nowadays (aftermarket or OEM) are not really linear anymore. If not mistaken, they are linear at the first few inches of compression and shots up after that. It can be noticed that the distance between coils varies either top or bottom part. Correct me if i am wrong. Just some cock and bull story. Hahaha!
ken12292703
1,542
5,138
SoMeWhErE
Change the springs will be the best solution. Putting cussions between them will harm the springs a little because of the ununiform stress and unbalanced load.
streetking
50
may be u can try to call speedtune performance corner, he is very experience in suspension. tel:019-3366948 SAM
iSkO
7
im using GAB Springs on my Myvi so far after a few months still no complaint for my end. i think the structure of our Myvi's are like that i dont know if you noticed it before when you just got it first time you will notice it already the front is quite higher than the rear. so if you put 3 big guys at the back you will notice it even more.
my suggestion is better you check it properly as long as the ride and feelings are good then just setle for it or can buy a new one since there are now a couple of good springs out there ( Eibach, Tanabe, TRD Sportivo and GAB ) also can try the adjustables a few are out there also (Titan, HWL and soon GAB ).
You can try and ride my car next time we meet.
A329878
125
JOHOR BAHRU
I think this one will better that "rubber spring"
The Splitfire Spring Adjusters are fitted in between the coil springs and helps to keep the springs apart during compression. This helps to increase the springs rate as well as reduce the sagging of the suspension system. The ride height of lowering springs can be increased to reduce scraping of the tyres on the fender and any bottoming out of the suspension system.
Key Benefits
Increased Spring Rate for better handling.
Reduce Bottoming Out of Soft Springs
Increased Ride Height when ferrying Heavy Loads.
I think I just blown the fuse to my Satria's room/roof light/lamp =X. I was trying to DIY LED strips to light up when the door open but I forgotten to disconnect the battery. The roof light wire touched each other and it sparked. I then tried to reconnect it, but it wouldn't light up now =X. Anybody know which fuse should I be looking at? Is it under the dash board or in the engine bay? =X. It is a 1995 Proton Satria 1.6XLi model.
