For immediate sale.
MSD Digital Dis-2 Rm1450 SOLD!!
MSD Dis-4 Plus 4 (2 units) RM 1850 each ONE REMAINING!! NOW GOING FOR RM 1700!!
Slightly nego
All items used but in perfect condition. harness included.
Item in Bangi/Shah Alam
TECHNICAL FEATURES - DIGITAL DIS-2
Operating Voltage: 12-18 volts (neg. ground)
Operating Current: 5.3 Amperes @ 10,000 RPM
RPM Capability: 14,000 RPM - 4-Cyl. @ 14 volts
Ignition Inputs: 2 - DIS Type
Ignition Outputs: 2 - DIS Type
LED Indicator: Ign. trigger, low battery voltage
Tach Output: (+) 12 volt square wave, 40°
Duration
Rev Limiter: High RPM - Adjustable
Low RPM - Adjustable
Spark Duration: 20°- 4-Cyl. Max Sparks - 12
Energy Output Max: 105-115 milliJoules per spark.
Output Voltage: Primary (into coil): 460-480 volts
Secondary: (w/stock coil)
43,000 volts
Weight & Size: 3 lbs., 9.5"L x 4.5"W x 2.2"H
TECHNICAL FEATURES - DIGITAL DIS-4 PLUS
Operating Current: 10 Amperes @ 10,000 RPM
RPM Capability: 14,000 RPM - 4, 6, 8-Cyl. @ 14 volts
Ignition Inputs: 2, 3, 4 - DIS Type
Ignition Outputs: 2, 3, 4 - DIS Type
Duration
Spark Duration: 20°- 4, 6, 8-Cyl. Max Sparks - 12
43,000
volts
SMS/Call Ayil 0123923553
(If dial tone sounds different to standard (I'm overseas), please SMS
Slightly nego
Duration
43,000 volts
Duration
43,000
volts
