I might not bothering to attempt this haha. I haven't even installed my evo cams yet! Have dropped boost down to 12psi until i sort out BOV issue and install cams/front 3" down pipe.
Only Partial. Will try today again and will see what happens.I still don't have the injectors setup quite right (running a bit rich under boost) so I can't really say how much difference the intake manifold has made... It doesn't feel much different on the "butt" dyno but I need to log some runs with virtual dyno to compare.
The Bosch injectors are high impedance (same as STI pinks etc) so no need for a resistor pack.
I did have to re-wire the injector plugs though as they are different, so one more thing to consider if you are looking to go down this route.
I still get a bit of compressor surge under partial throttle too... I've cut the soft spring in my GFB response further and each time I do this it helps a little more. I have to run the BOV fully recirculated now (no vent to atmo)
Are you getting the surge / blowback on partial throttle or full noise?
