LSD Gearbox Vs Gear Oil
JackWaiKit
262
5
www.friendster.com
Yo all sifu,
I would like to ask y'all about...
is really LSD gear need to use specified gear oil like 'indication' of different brand...
What I'm trying to ask is...can LSD g/b use normal gear oil???
Thanks for viewing & reply!
khoyos
2,632
156
5,163
Shah Alam
LSD gearbox must use LSD gear oil to protect the internals of the gear n the LSD mechanisms... non-LSD gearbox can use LSD oil but not the other way round...
JackWaiKit
262
5
www.friendster.com
Yo bro,
Thanks for reply...
I just thought... LSD just a part in between the driveshaft...
But no idea how sensitve it is to the gear oil...
Anyway... it means it's sharing gear oil together with the gear... doesn't it?
But if the tear starting tear of worn...could the LSD also be affected?
khoyos
2,632
156
5,163
Shah Alam
if u notice, the final drive (which is where the LSD is located) is also lubricated by the transmission oil...
the big gear on the right is the final drive. beneath the final drive is the lsd n u can see the big gear is also lubricated by the same gearbox oil that lubricates the gears (the 2 shafts on the right with lots of gears on them)
JackWaiKit
262
5
www.friendster.com
i was used Motul 75w/90...
damn...90 per litre...my g/b need 2.x litre...need to buy 3 litre...
can u imagine!??!?!?
I have a Nissan sentra year 2003 and i had a lot of jerking issues. Basically i brought it to the shop to diagnose and its said to have sensor issues and they replaced the crank sensor and camshaft sensor and reconnected the ecu and it is still showing the same error so the foreman said the ecu is faults and he cant find a a replacement.
I need advice from how to go from here as my car is in melaka. Where is a place i can get an ecu?
Ecu code number is MEC13-411
Please help! still...
