Lousy Turning Angle
Bevan
Does any other honda drivers feel this? My honda civic year 2002, its very hard to make u-turns. I drove many car before this but non has any problems making U-turns. How come this car cannot make a full U-Turn, Especially drving in KL i have to turn half way then reverse then complete the U turn. People will horn me kao kao la. Is this a standard problem or problem with my car. Any suggestions on how i can improve the turning?
ES kut..??
yalah, Honda made for sport driving & track/race using... high speed stability, a bit under is a must, just dun compare with other cheap makes...
use the hand-braking...:biggrin::biggrin:
errr. ok. but i'm already the u-turn so slow. Barely touching the paddle. Only my Honda has this prob. My satria and kia no such problem. Any other Honda Civic users facing this same problem?
Whats ES?
Whats ES?
ur civic is year 2002, so... its ES loo..
my civic oso cannot makes u-turn... need some speed & hand brake only can turn... haih...:banghead:
u compare Kia & Satria with Civic..?? hahahhahaa:rofl::rofl::rofl::rofl:
the ES is not listed, so the nearest i get is the EU civic,... i think the chassis like ep3 punyer,...
5.5m turning radius,... almost same like the accord,...
GENERAL
Body type Hatch
Drive FF
Transmission HONDA multiple matic S (automatic non-stage transmission)
Displacement, cc 1668
Frame LA-EU3
Price of new car, thousands yen (Tokyo area) 1648 (~$13700)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4285 x 1695 x 1495
Interior dimensions (LxWxH), mm 1885 x 1420 x 1230
Wheel base, mm 2680
Treads (F/R), mm 1470 / 1465
Ground clearance, mm 150
Curb vehicle weight, kg 1190
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 5
Min.turning radius, m 5.5
Fuel tank capacity, l 50
ENGINE
Engine model D17A
Max.power (Net), kw(PS)/rpm 130 ps (95.62 kw) / 6300 rpm
Max.torque(Net), N*m(kg*m)/rpm 15.8 kg*m (154.95 N*m) / 4800 rpm
Power density 9.15
Engine type Water cooling serial 4 cylinder SOHC16 valve
Engine information Horizontal ranging belt driving VTEC
Fuel system Electrically controlled gasoline injection system (HONDA PGM-FI)
Turbocharger No
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) Yes
Compression ratio 9.9
Bore, mm 75
Stroke, mm 94.4
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 5.8
Fuel consumption at 60 km/h, l/100km
i think among all the cars ive owned, honda city 4g has the best turning radius ..
its fixed isnt it ? or by changing smtg will improve it ?
Wahh.. need laugh so much meh? hahaha i just bought this car ma. Don't la laugh so much.
so whats the turning radius of satria?
