Losing Power (regardin Evo3) Help~~~!
DJ-LanEvo3
960
I feel that my engine losing some powers.....
The symptoms are...
- Bit dull and difficult to rev from RPM at 4-7k
- Running at 0.6 bar only.... and sometimes it seemed bit
dull to reach 0.6 but 0.5 on uphill...
- Less G-force.... after 4th gear... no G-force at all...
Any idea about this? or have any similar problems before??
Feel quite upset.... no power... :frown:
dolly
726
maybe you are used to the power edi? :D
hmmm, check your plugs, see if they are in good condition and check your ignition timing.
did you do anything to your setup before you felt a loss of power?
nitrus
2,895
35
1,648
The symptoms are...
u noe wat's best thing to do bro...? :biggrin:
bring ur car to experienced in turbo cars mechanic n get ur car checked b4 it gets worse... good luck..
omnikron
66
8
1,508
why don't you try getting your car dyno-ed, if you have dyno your car before, compare the old and new graph. but typically performance would deterioriate little by little due to age. if dyno no problem, then if most probably is you got used to the power. other diagnostic equipment such as compression test will alos help you find the root of your prob.
furious_evo
33
it sounds like a worn out flywheel to me....skim it b4?when is the last time u change ur clutch set?any leaks?
gavan
1,408
Shah Alam
hmm, might be cuase by a worn piston ring or vavle.....or maybe there is a leak somewhere as you are losing boost......kinda scary to think of it... better daignose it ASAP ;)
jinkl
4,624
376
3,183
i suspect something else
actuator is not right
exhaust leak
boost doesnt kick fast
and u already metal gasket rite ?
u cant put stock boost again bro , u gotta up it cos u have lost compression ..
DJ-LanEvo3
960
Wow... so many good comments I can see here...!!!!
I'm really appreciated to u all guys....
Yea.. for the first of all, I gotta see experienced mechanic
first... to see any leakings or other parts cause my car slow.. yea.. that's true.. Another thing is obviously I get used to
power of my car... haha...
Secondly... I need to do a dyno test to check fuel raito
and so on...
Thirdly.. yes I get Flywheel skimmed...
Forthly.. I equiped metal gasket.. oh.. then I might be running
with low compression obvisouly... I just forgot it.. haha
I'm dumb hahahaha...
Fifthly... I used to run with original Evo3 set but currently
I'm running with VR4 block.. it's components inside such as
conrods and crankshaft all that.. it's much heavier than
Evo3.....
Thanks for all the precious comments... I roughly know what's
going on my car now... hahaha.. I gotta see mh mechanic to
discuss about this all..
zakie
131
aLo kawan....
u'r engine evo III standard giLor ka??
intercooLer piping?? metaL gasket??
0.6boost?? aLo bang.... baru pakai turbo kerr??
mana nak feeL G kaLau 0.6bar jerr?? :thumpdown
the Gs onLy can be feeL at 1.0 & above onLY maaa....
0.6bar side bY side with v-tech 1.6(smaLL vtech) confirm "berkampong" kono..... :tee: .... normaL evo III aLso bar at 0.9bar, how come u'r engine run at 0.6& 0.5 bar?? :eek:
if vR4 standard Yes i beLieve u'r boost at 0.5&0.6 bar...
sori if mY worDs a bit kasar Loorr... :rock:
:dancing2:
reintel
732
30
3,028
strange! how cum my vr4 standard boost 0.8bar & mention here is 0.5-0.6?
zakie
131
reintel...
dont get mad... :tee:
Yaa Loorrr..... vR4 standard wiLL be at 0.6bar.....
if u'r machine is standard and the boost is cLimbing from 0.6 to 1bar there must be sumthin' wrong oredi with u'r actuator vaLve... carefuLL arrr.... Later on u'r machine wiLL easiLy spoiL... :secruity:
trY Loorr ask u'r foreman about the boost for standard vR4, sure he wiLL agree with me, unLess he oredi did sumthin' to u'r ECU .......
:rock:
:dancing2:
DJ-LanEvo3
960
-Considered stardard but using VR4 set up for block only.
-Yea, stainless intercooler
metaL gasket??
-Yea, 1.2mm
-Reconditioned Turbine..
-I used to run at 1.5 bar. It was due to hose leaking haha.. but now I'm running with 0.6 bar. We can feel Gs at 0.5 also... (May I know what engine u got under the hood?)
NormaL evo III aLso bar at 0.9bar, how come u'r engine run at 0.6& 0.5 bar??
-Hm... actually R u own a Evo3 engine or u've heard the story that Normal Evo3 running at 0.9 from ur friend?
I have bunch of Evo3 engine owners.. but... stock everage boost is 0.7 bar...
Can u plz specify ur comments with more proven facts to
enhance my knowledge... I'm kinda beginner here...
reintel
732
30
3,028
zakie,
dont wori, we all here to learn. my engine mod alot already, thats why run at 0.8 bar.. hehehhe.... before dis never got the chance to c it run standard coz when i purchase it, straight away do internal mod.
zakie
131
GuYs motorsport Fans :rock:
actuaLLy there is 2 type of boost meter reading...
1 boost meter that using controL box which mean the reading is base on controL box reading where is the vacum connect to the controL box, and the controL box wiLL send the info to boost meter.
2 boost meter direct to vacum.
this 2 type of boost meter wiLL sure give u adifferent reading when u'r turbo car is in idLe...
i'm aLso using evoIII machine previousLy, now oredi change to sumethin eLse.... he he he cannot teLL Loorr....
thats whY u need 2 noe wat tYpe of boost meter r u using and the resuLt that u'LL get.... maYbe a bit higher or a bit Lower,
:dancing2: :dancing2: :dancing2:
hi
im currently using wira aeroback 1.5 to mod with 4g93 block + mivec head + MMC ecu
.is it ok or the machine will giv problems to me in future.
