Karnival Permotoran Belia : Super Time Attack Challenge 2008
dzal_a
392
Date : 9 & 10 February 2008
Venue : Shah Alam Stadium,Carpark
Category
Class A – Below 1300cc
Class B – 1301cc – 1600cc
Class C – 1601cc – 1900cc
Class D - 1901 And Above
• For turbo car times 1.7 with the engine capacity
Prizes(each Category)
TBA
Entrance Fee
RM100 per perticipant
Contact Person
Faidzal Alang(dzal_a) – 012-555 0616 (Time Attack)
RULES & REGULATIONS
CAR
- Cars need not be registered for road use, however ownership papers and documentation is required
- Roll cage, 4-point safety harness and fire extinguisher in car are recommended
- Empty the interior of all unnecessary items No loose item in car
- Headlamp & Brake light must be working
- Handbrake must work
- Wheel nut must be tighten
- The interior may be stripped of carpets and rear passengers seats
- Tyres must have a minimum of 3mm tread. Bald tyres will not be allowed.
- Slick tyres are banned. Roadlegal semi-slick tyres will be allowed
- Different types tyres front and rear are allowed
- Any modifications to the vehicle may be carried out including suspension, engine, braking, transmission, and interior. However, these must comply with the minimum safety requirements
- Body modifications on the metal body panels that after the appearance of the standard vehicle are allowed.
- Lightweight body parts of different material to the original are permitted
- The organisers are not responsible for any modifications to the entrant’s vehicle that is carried out not in accordance to the Road Transport Department regulations. This is your responsibility.
- The organisers have the right to exclude and deny entry to any vehicle that does not comply with or meet the above safety requirements on the grounds that the vehicle is dangerous and unfit
DRIVER
- Helmets , Shoes and Long Pants are required
- Racing suit & shoe are recommended
Hi to everyone.
Exhaust Gas Recurculation (EGR) is actually a small valve that recirculate a small amount of exhaust gas back into the intake manifold.
They were designed for that because some ppl claims that by sending warmer gas into the combustion chamber, the air/fuel mix does not have to do as much work to heat up, and your engine runs more efficiently or even has a cooling effect on combustion temperatures that helps reduce the formation of oxides of nitrogen.
Ok my...
