Iswara Radiator Temp
LAWRENCE_Q
428
JB
jz now home, saw that my radiator indicator point more than 1/2, it is rarely happen!
wat's wrong????? :blink:
another problem is tat my engine more noise after service, is it due to the lubricant oil??? i jz change 2 a 10W-40 caltex from 15W-50 esso!
during service, i oso changed oil filter & plug.
Viperize
31
i also got this problem last time... did u check the water level ? enuff ?
when is the last time u service the radiator ? maybe ur radiator stuck already.... the water can't move smoothly / move slow.... in this case just send ur car to service the radiotor then ok already.
Note : Fix it before the temp when up again... or else it will hurt ur engine
escaflowne
1,006
my opinion is nothing gonna do wit ur engine oil.from 40 to 50 engine oil normally wont cause the temp to rise. sometimes my saga also same like urs..i go get a new coolant..cost me around 13 bucks..
wash kao kao the reservior tank...flush kao kao the radiator.and yeah...full wit rust water and all sort of dirt.pour 3/4 coolant to the radiator and 1/4 into the reservior then mix wit water.
and now..my car temp hardly pass the Cold mark..maybe just 1 cm away.only if go up to genting or rev kao kao only go up to medium or more abit.that's all.quite satisfied,but engine takes longer time to heat up...too cold kua.this i am blur.
lix
152
Ask your formen to check the thermostat. If rosak.... just change it. Very cheap only and remember to flush the radiator. Good luck
lix
152
guys,do u kno where to install sunroof from chop shop?...i got dis mitsubishi gsr sunroof to install in satria...after shop roun',they quote me round 650-750 for installation charges...but paint not included...i heard in banting they charge roun 350 including wiring....so,any recommend shop here in kl with affordable price????....help me yah....thanx
