IS250 couldnt start!
alfeoturbo
152
Sel
Dear Forumers...
My IS250 couldnt start at all after a day i did not drive the car.
Mechanic check the fuel pump is working fine and the car cranks when ever i press the push start botton but it just couldnt start.
Anyone experience this before?
Nats autoparts
411
20
just go to toyota/lexus center
they have diagnostic set to be able to determine the failure
before you do even tow the car
you need to let them know your car spec
as variant spec will have different electrical system setup thus some of the diagnostic software wont
be able to support and capture the symptoms
and also to avoid losses because of towing the car.....
SomeGuy_sg
159
6
5,018
Your explanation of your problem is very vague. So your car can not start.
When you turn the ignition on , do you hear the fuel pumps come on ? Does the battery have charge ? When you crank, does the starter motor turn over ? Do you have fuel pressure ?
Please do not just say that your car can not start.
EvolutionZ
5,000 RPM
5,025
1,448
anything to do with yr immobilizer?
maybe call yr salesman and he might be able to advice...or refer to the right technician...
matshah
814
37
my mark x also couldn't start..mech check wth diagnostic tool also no fault..Mech service t throttle body then its OK again
I got few question about this air ram...
The twister air ram(also known as whale penis,guppy intake, dugong,J's racing air ram n ect)... is it recommended for mivec??
what's the advantage for using this air ram that used by most vtec's car??
some said that the it give a nice sound, gain more hp than stock air ram but some also said that cant feel anything.....
I went to Kakimotor at sunway... and he offer...
