Imported valvoline fully synthetic synpower 5w-40 engine oil
Apache91120
Klang
For high performance modern turbo charged petrol and diesel engines.
SynPower 5W-40 Synthetic Engine Oil
LL01 specification suitable for BMW and Mini.
Suitable for use with alcohol fuels.
Low phosphorous, low sulphur safe for 3 way catalysts.
SynPower SAE 5W-40 is a full synthetic engine oil developed to meet the requirements of the new generation “high tech” engines and to satisfy the severe conditions experienced during motor sport competition. The ability to control the chemical structure of synthetic base oil provides performance markedly superior to mineral based motor oils.
This oil is a low phosphorous motor oil which is suitable for vehicles fitted with catalytic converters. It is also suitable for turbocharged petrol engines, naturally aspirated and turbo-charged passenger diesel engines. It can be used with alcohol fuels and is recommended for
high-performance and race developed engines where a multigrade, synthetic oil is required.
Approvals and Performance
SAE 5W-40, API SN /CF, ACEA A3/B4. Meets requirements of: BMW LL-01, MB 229.3, GM-LL-B-025, VW 502.00, 505.00, Renault RN700, RN710.
SYNPOWER HAS YOU COVERED
SynPower is Valvoline’s Full Synthetic engine oil. Formulated with quality base stocks and special additive packages, it meets the high performance standards and efficiency regulations required by modern engine manufacturers, and gives the ultimate in performance and protection for your engine.
Whether your vehicle is in the harsh conditions of everyday stop start traffic, or experiences long highway journeys, your vehicle – and the environment – can benefit from SynPower.
Compared to conventional oils, SynPower flows faster to all parts of the engine due to its thinner viscosities and helps maintain fuel efficiency for the life of the oil, giving ultimate performance and protection in all climates and conditions.
SynPower is compatible with all conventional and synthetic engine oils when used with its equal performance level grade, and has excellent deposit suspension, superb piston and engine cleanliness, superior cold start and excellent high temperature performance, whilst also meeting the high performance standards and efficiency regulations required by modern engine manufacturers.
Benefits:
- Provides excellent engine cleanliness through superior sludge and varnish protection
- Helps reduce engine wear at high temperatures with improved viscosity stability
- Provides outstanding high-temperature protection under severe driving conditions
- Provides superior cold-temperature protection through faster oil flow at start-up
- Helps improve and maintain fuel efficiency for the life of the oil.
TEL: 012-9154001
MADE IN USA.
A thread every 60 seconds
