If use oil cooler, do I need to upgrade oil sump?
Sil80-13
1,215
44
Hi,
If I want to install an oil cooler, is it a must to upgrade my oil sump as well?
Sil80-13
1,215
44
Opps...Sorry. It's Oil Pump. But some ppl call it oil sump. Right? :biggrin:
Means upgrade to larger in order to install oil cooler. It's a MUST?
It won't hurt to have faster flowing oil since you're reducing the oil pressure by adding the cooler. But this is highly dependent on the type of cooler you're installing. If it's a small one and doesn't affect the pressure much then no need la. If you're gonna go bigass with the cooler then most likely a stronger oil pump would be useful
ken yeang
6,617
1,327
faster flow of oil is good, but moving bigger oil volume at a higher rate with upgrade oil pump will cause parasitic lose for the engine. You gain something, you lose something...
The Unlimited class in Pikes Peak is the craziest class of racing you might ever find, bar funny cars on the drag strip. That however, hasn’t stopped Paul Dallenbach from roughing it out with the big boys with his machine that was still in its infancy last year.
Although packing a whopping 745hp last year, that just isn’t enough to cut it in the big leagues, so Banks Power lent Dallenbach a hand by...
