How to take out, rear cover for satria
softmuffin
384
Hello zthm,
Need guide lines from you all in how to take out the cover for the rear (left and right side) The cover i means is the one where all rear speaker is?
Anyone ..
simefly
449
just get a thick cloth(to lay it and use it as the base) together with a minus screw driver / something flat... Behind these are just clips... but becareful not to scratch the interior tho..
Have fun
softmuffin
384
Hello dude,
Alright but how about the screww at the back of the boot? As i know, the cover is from the front (before the front door) to the back at the boot. Where there is few screws connected together with the cover bolted at ther rear suspension ...
do you get what i trying to say?
Have fun
ealt
2,395
16
You have to dissambles the rear cover first (Back cover), after that, start from back to front to open it.remember got screw below seat that you have to take out.good luck
softmuffin
384
Yeah... i think i get you.
need to open it to change the door rubber for (door and car body) both side.
and the saftely belt
ealt
2,395
16
You should put nicely when putting back the cover if not you will got some melody....citt....citt..something like that....hehehe...carefull my friend
ealt
2,395
16
I recomend you to put some sound proofing material at the back of the cover...trust me, you will fill good when you play your HU.....mine working goods...
softmuffin
384
Whahaha, i wish i could lah but the door rubber full set (door and car body) already burn me Rm150
simefly
449
Oh... you mean the whole interior? I thought you specifically wanted just the speaker bit... My wrong..
Well, as explained above.. hope you got all that right...
ealt
2,395
16
Not too expensive, i bought one from ninja_iga, rm32....but have to do by yourself....
softmuffin
384
Thanks dude,
will hit his a call
ealt
2,395
16
You should buy glue from hardware shop...buy dunlop brand,rm8.00. You can also put it onto your door....no citt..citt sound anymore....n also good soung when play my HU......just want shared....
softmuffin
384
Hello dude,
Glue on my door. since when my door need to use glue?
yeah rite now my door making lots of sounds when go over bump. i think the sound is from the inner door lock system. (you should know wat imeans when u open up the door panel)
But i wonder why got sound since the door lock system besi.
I hav try to take out the door panel but still got sound..
need to replace the door rubber first coz when rainning, water can come in (driver side) and wind sound if i speed above 80.
ealt
2,395
16
what i means is u should put the sound proofing material on it.cover all the inner door.good sound when u bump your doors...
Victa
25
Kuantan
U mean the behind there where u want to fix the speakers??? If u want to open thet cover just take a small screw driver and open it... Correct me if im wrong... Because thets the cower for the speakers right?
