sifus.. i wana know how to know the RMS rating for amps which onli stated for example 300 watts.. or 50W per channel.. how can i know the RMS rating? can calculate?
Can be calculated! but i don't know how...Easiest way is to RTM (Read The Manual) ;)
It's stated there for eg.
75w X 4 @ 4 ohm etc etc..
i hope that helps :)
usually RMS is half of the max power. it is very difficult to know whether its max power or rms power.
one way is try to check the fuse rating. if it has 20 - 30 a fuse but claim it produce 1000w would you believe it? there is a lot of ovveratted amp out there. so before you buy an amp, do your homework first.
Guys, i'am experiencing "non responsive pedal this evening"....while cruising at approximately 100km/hr
my engine light light-up and my accelerator pedal did not response for any action...the engine and other function still on, luckily i able to...
