To determine whether the lower arm needs replacement, you need to visually check the condition of the bushes. Lift up the car and look for cracks or broken rubber on the bushings. If they are not visible or you are not sure, pry the bushings using a pry bar and see if the bushing is very loose. If yes, they need to be replaced.
