- May 28, 2006
- 227
- 3
- 1,518
Hertz Audio HP4 Car Amplifier - RM1,400
Dealing method: COD
Location of seller: KL/PJ/Melaka
Contact method/details: PM or WhatsApp me at 012-2509890
Age of item: 2 Months
Item(s) conditions: 9/10
Reason for sale: Change Car
Specifications:
- Class AB- 4 x 130w RMS @ 4 Ohms (CEA 2006 Compliant)
- 4 x 230w RMS @ 2 Ohms- 2 x 440w RMS @ 4 Ohms bridged
- Extruded Aluminium heatsink with cast end pieces and smoky top plate over crossovers, plus HP Manager panel and button.
- 3Ga. power terminals with Allen headed grub screw connection
- Dot matrix LCD display plus LEDS system called HP Manager showing Voltage and temperature in degrees Celsius and Fahrenheit plus protection status
- 4Ch RCA input, 2 RCA output plus high level input on supplied separate connection system
- 12dB per Octave Highpass/Lowpass crossovers 40Hz to 150Hz
- Input sensitivity: 300mV to 5V or 1.4V to 2.4V high level- Stereo & bridged operation
- Frequency response 4Hz to 70kHz +/-3dB
- Signal to Noise Ratio 94dB
- Channel separation not quoted
- Fuse Rating 30A x 4
- HxWxD(mm) 58 x 240 x 550mm
Review: https://www.talkstuff.net/index.php/index.h.../hertz-hp4-r367
Dealing method: COD
Specifications:
