Help! tuk.. tuk.. sound when cornering
beatnik
924
74
3,028
I asked my bro to send my car for checking.. got tuk.. tuk.. tuk sound when cornering right.. so sound coming from left.. but now on right also got tuk tuk a bit when cornering left.
confirm not drive shaft and arb as i've changed them recently. the mech said it is bar ring.. what the hell is that? anti roll bar ring? or he meant link? i dunno coz the car is not wit me, so cannot see.
mech said it costs RM95 each.. so both side inc labour RM240.. expensive?
car is sgti
kenchao10
102
ya, having the problem last time, mine was the anti role bar.. cost me abt RM95 to change including labour..
cck2228
256
Sandakan,Sabah
wow//my car also got..only when i turn to left the sound will come out from left behind the car!!
Huh..i also donno what is that oo..maybe the body? or what leh? any sifu...
Im driving Toyota Altis
xin
626
if it is not the driveshaft or the Anti roll bar ..then there is another joint connected to the discbrake there ..its like a joint and has something to do wit alignment .. maybe tat small thing was broken ..if the plastic cap above is broken then just replace the plastic cap and apply some lubrication then will be no sound ...
if the whole thing broken then it cost around RM60-70 for a pair
the plastic cap cost onli around Rm5-10 a pair ..
how to check if the joint is rosak ? easy u try to move it ..and if it is too loose then it is rosak hehe
beatnik
924
74
3,028
thanks xin
maybe i should go to another workshop. went to skyzone but they cannot identify the problem.. :confused:
johndoe
345
last time my car also like that. should be drive shaft problem.
ANDY_RESORT
820
www.andymervingeorge.com
Bro, it could be your suspension. COz I had the same thing too on my wagon but when I replaced the suspensions on both front then ok liao!
Try to notice whether the car is lower on either side on the front suspensions... usually on the driver's side. If its lower on 1 side then confirm suspension problem since your shaft and arb have been changed.
Good luck and PM me the results if its what I smell. Just my few cents... ;)
cck2228
256
Sandakan,Sabah
Thanks to all giving me some points!!! Hope the car can be ok! :)
Thanks Everyone!! but so many reason which will make the sound wo..which one leh?
Andy_resort= But u say one side lowered?? mean
izzit the height of tat car is different? yes , mine is..
front= the driver side is lowered than passanger
rear = left is lowered than right one
After i lowered my Toyota Altis i realise the car height is diff.donno the spring problem or the suspension problem lor..Can u help?
vyx
63
Selangor
got the same prob on my wira..
changed my anti roll bar, arms, and bush.. and everything's fine..
beatnik
924
74
3,028
sent my car to workshop again today and it turns out to be the absorber link is damaged. changed the left side and sound is gone.
ANDY_RESORT
820
CCK, yup, its confirmed that your front suspensions need to be replaced. The rear one check whether got oil coming out from the absorber or not. Just bend down and see it from the rear trunk.
Lowering springs is actually not recommended. Its best to use standard lowered springs usually are sport springs then ok. Dont potong the ori springs just to get the lowered look. Try other options, if tak jadi at least you still have your stock suspensions.
Send to shop and check it la.. confirm is the suspensions front driver side and left rear side problem... surely no tuk tuk sound.. but prepare a few hundred bux (at least)
Ganbatte!
cck2228
256
Sandakan,Sabah
Ganbatte!
Maybe you are true my fren!!! Then how to i find the New Suspension to replace oo..aiyo...Very mafan...Buy one set also cost 1000++
Of coz not potong la..im not stupid.hehe..I use G|A|B spring to lowered the car enuf..
Can your tell me what cause the suspension rosak like my car?? Is it drive on bumpy road too much?
Then you said send to shop to fix , can fix gemeh???
U mean the front need to replace and rear can be fix izzit.. why front need to be replace to new one?
Thanks for your advise man!!
And everybody too!!:rolleyes:
beatnik
924
74
3,028
elo all
is it possible to change the bushes of ARB link? it's making tuk tuk sound so do i need to replace the link? or just change the bush?
gavan
1,408
Shah Alam
erm, i think the problem is the bushing, wether it come from back or front, please do check all the rubber bushings, mine also got this sound, butthen i no time to trobleshoot it also, but most commonly is the bushings larr...sometimes could be those links at the front when you turn your steering, got tuk tuk sound come out.....see the links from the wheel to the body wether got loose anot..normally got small bush there to prevent noise :D
This everning found my kelisa wind screen cracking and going to more n more serious :'(
Anyone any idea where can change it in Penang?
What is the reasonable price for changing whole wind screen?
