[help]How to install Power Cap?
yewnen
39
Malaysia
1du.org
[help]How to install 3 Terminals Power Cap?
Hi!
I'm Lau, newbie from Kuching, Sarawak. I bought a Power Cap (Pioneer 2.0F) and I'm facing one problem. Need sifu's advice and help.
unlike other power cap, there are 3 terminals on the capacitor unit as shown in the attachment. Where should I connect the AC to? :frown:
yewnen
39
Malaysia
1du.org
cacin said:
yours come with digital voltmeter right?
is the other one labeled AC or ACC?
Yup! It comes with the digital voltmeter display. There are 3 terminals, one with label AC, the other 2 no labels, only color red and black. :frown:
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
ac is the remote from ur HU, red is the direct from ur battery, black is the ground
rite?
cacin
1,000
5
5,138
Penang
caution
if AC is to be connected to remote turn on from the HU, please make sure you do not put to much strees on it. Like connecting it to other devices that needs remote turn on like amps, eq and active x-over. Try use a relay for this and make sure it is fused.
Hope this helps.
yewnen
39
Malaysia
1du.org
Hope this helps.
So the AC terminal is connected to remote turn on from HU? if confirm, then i'll connected the remote to to trigger the relay to connect the battery voltage to AC terminal. OK?
yewnen
39
Malaysia
1du.org
I have connected the AC terminal to the ignition/remote. It functioning satisfactory. Thanks a lot! :shakehand
While details may be vague, it’s reported that Ferrari Chairman Luca Cordero di Montezemolo has acknowledged that the replacement for the Ferrari Enzyme will “incorporate the state of the art of our knowledge in terms of increasing performances while reducing fuel consumption and emissions. It will then influence all Ferraris that appear after...
