Hi Guys,
I've just purchase a 2hand Ford Laser Cabriolet 1986 E5T(Jspec). The car came without a Turbine & Intercooler (Yes! previous owner took it off.. gods knows why). The car is pretty much standard accept for the ciplak Timer & Turbo meter. Not to mention, has a staright flow piping (2inch)... sounds like a Bas Kilang.
Parts which ive change:
1. Standard Air Filter
2. Oli filter & Engine oli
3. Replace all the small engine rubber hose
Problems:
1. Makan minyak macam giler - RM50 > 220km max.
2. Loud noise coming from the external oli filter. When the signal light is switched ON the noise follows the Blinking indicator.
3. Air cond was working fine before... but it gave way 2 weeks ago.
4. Timing is very high due to the Air Cond wiring.
5. Black carbon mixed with water comes out from the exhaust pipe.
6. When the car is driven above 130kmh, engine sometimes starts to die off while driving... gives a jerking/pulling feel. After pressing the clucth engine comes back to normal. This only happens sometimes.
7. Brake system sucks.
8. Power stearing is dam hard. Need to top up the oil every month.
9. When heavy rain, water starts to drip through the soft top joinings.
Solution:
Short term - plan to fix whatever part is afforable to reduce the pertol consumption.
Long term - plan to buy a half cut.
Can you guys please help me out here. Need your advice on which halfcut to purchase.
Basically, I do lots of travelling(600-800km a week). I need an engine which will consume RM50 for 270km above and produce good horse power.
Should I stick to turbo or n/a??
Any suggestion??
Rgrds,
Problems:
Solution:
Any suggestion??
Rgrds,
