GReddy e-manage blue.
Ming Motorsport
304
=[WTS] Greddy E-manage Blue.
= Cash and Carry.
= COD are Available (Cheras Area)
= 100% New From Box.
= Suitable for Street Use / Performance Drive.
= RM1100
Product Description:
•Fuel Delivery - Compensate for upgraded mass air flow meters, throttle bodies, or fuel injectors.
*Adjustment of fuel delivery at 5 different RPM ranges
*Adjustment of air flow meter signal by up to 20%
*Incorporated Fuel- and Boost-Cut Controller
*Control of up to two additional injectors activated by boost or RPM level (with optional boost sensor)
*Idle adjustment circuit included
•Ignition Timing Adjustment - Control your ignition timing under high-output conditions (with optional timing adjustment harness)
•VTEC Timing - Have one of these in your car? Now you can do even more!
*Set valve timing based on Engine Speed
*Use your factory non-VTEC ECU with your VTEC engine swap!
The EManage even features password protection of the user's setup and stores its settings in non-volatile memory so settings are not lost if the battery is disconnected or dies.
For more performance part inquiries, pls feel free to contact/SMS/Whatsapp/WeChat/E-mail @ below:-0125117099
Helo all sifu, :adore:
Was wondering what the maintenance cost of a toyota supra..
example:
how much is servicing?
if i overhaul the engine how much?
if i change from auto to manual how much?
reliability?
and anything else that you think i should know...
plz help, thank you very much..
