gearbox problem for wira a/b 1.5 auto
suresh77
10
my car mileage currently is 130K ++, for the past few weeks, my car have been experiencing jerks between changing gears(auto), it feels more like it is hesitate to change.Anyone experience this before ?
Is it gearbox problem or is the ATF fluid ?
Can anyone enlightrn me on this problem ?
Thanks.
CoolFusion
75
PJ
i fucked up my moms car... same type... i think its eather the auto clutch or u gotta service the whole gearbox... like:-
Reset auto gearbox's ECU...
Transmisson Fluid...
Check The Clutch...
i think it is... juz send it for a service and ask the guy...
ksgoh
1,392
9
Kedah/Penang
Thanks.
ever change ur gearbox fluid??
lix
152
i thought 1.5 wira auto transmission didn't controll by ecu:confused: :confused:
BTW did you change the ATF together with the transmission filter?
jswong
209
9
Same thing happened to my car, and next thing I know, the auto clutch kong even though I change my ATF and filter before 20,000 km each time.
To tweak the shift timing, you can try adjusting the throttle sensing cable.
Look behind your throttle body - there's a small L-shaped metal harness, and a bolt is holding on to a bracket. The bracket has a cable fastened to your throttle spool, and this cable goes to the auto box.
Loosen the bolt and slide the bracket a little lower.. just a little.. that will help the car shift earlier and hopefully eliminate the jerky shifts.
Maybe sludge is building up in your valve body already.. in any case, playing with the throttle sensing cable will adjust the shift timing.
ykchia[fotb]
21
Subang
It happen b4 to me last two ago...
It have too much posible problem. Mayb is the time to service ur auto gear-box...if u just ignore it will need to change the gearbox sooner or later....
This the my experiance of destroying 3 auto gearbox n 2 year...
<iframe width="335" height="250" src="http://www.youtube.com/embed/vXTRWXKL54Q" frameborder="0" allowfullscreen></iframe>
Who remembered the Ridge Racer franchises from years ago? This is one great arcade game to spend time on. This game is very much like Burnout series, where you are involved in a demolition derby, racing each other in town. Although I feel the graphics are a bit lacking (as compared to Grand Theft Auto V anD Need for Speed : The Run) , I'm sure the game play should make...
