Force Induction For MIVEC
ZamS
212
Dear Friends,
Need some info regarding Force Induction (turbocharger / supercharger) for 4G92 MIVEC. Advantage/disavantage?:rolleyes:
HP Gila
20
ZamS said:
Dear Friends,
The modifications are required as below for maximum boost pressure of 0.6kg/cm.
  • Reduce piston compression ratio to 9.0 - 9.5 which to allow no spark timing delayed.
  • Fit Boost-Cut Eliminator to allow original NA. ECU to operate normally when it sees turbo boost.
  • Supply more fueling for correct air-fuel mix. till 0.6kg/cm turbo pressure.
  • Fit large enough intercooler for better performance & durability
  • Fit VTEC [Valves timing engagement control] Controller to activate MIVEC when boost in at lower rpm.
psyk
415
your nick.. handphone gila ker.. hewlettpackard gila? hamsap gila? :D
deacon
Senior master debater
1,165
30
or get a developed sc for mivec engine like Jackson racing has for the b16a engine for honda hehehe :eek:
Hey guys,
I have a couple of wrench.My question is, can i adjust the absorber without dismantling it?Can i just jacked my car up and adjust it from there?If yes,how do i do it?can enlighten me?Thanks in advance.
