Ming Motorsport
="Red"]=[WTS] Exedy Racing Clutch for Proton Wira1.6, Waja1.6, Gen2, Satria Neo.[/COLOR]
= Cash and Carry.
= COD are Available (Cheras Area)
= 100% New From Box.
= Suitable for Street Use / Performance Drive.
= RM800
Cerametallic Friction Disc
= EXEDY Exclusive Friction Composition.
= High friction coefficient material handles much more heat than stock-type without slip or fade.
= Designed to handle workload of higher horsepower.
= Heavy Duty oil-quench hardened damper absorbs shock.
= Hi-load bonding agents retain clutch material.
= Reduced weight = lower inertia = quicker shifting, less wear and tear on synchros.
Thick Disc
= Better heat capacity than Ultra Fiber Organic.
= Lighter disc assemblies mean less inertia for quicker shifting.
= Works well for Street, Rally and Drag.
High Performance Cover
= Average of 40% increase in clamp load.
= Extra capacity holds common street car upgrades.
= Ductile iron pressure plate provides high strength anti-burst protection in all temperature ranges.
= Stamped steel cover designed to reduce deflection.
EXEDY cerametallic clutches are designed to handle the abuse of high powered modified engines. Our cerametallic friction material can handle much more slippage than stock type disc assemblies without slipping and fading. All cerametallic discs feature spring center dampers to reduce impact and shock loads.
For more performance part inquiries, pls feel free to contact/SMS/Whatsapp/WeChat/E-mail @ below:-0125117099, [email protected]
= Cash and Carry.
= RM800
Thick Disc
