Evo 3 turbo and piston upgrade HELP !!
Hadi17
145
10
518
Johor
Help me all sifu's ! i want to upgrade my stock evo 3 turbo to bigger one .. but i'm not sure what turbo to choose between A/R60 or TDO5 20g or A/R 70 :confused:
when i upgrade the turbo can stock piston tahan the boost from big turbo ? or should i change the pistons ? what type of pistons should i change ? :bawling: headache :mad: !! PLEASE HELP ME OUT
fazidk
413
Hi bro hadi..I'm x expert but if u wanna change bigger turbo it has to compliment wiz other mods s well eg. Injectors,fuel pump,piggyback or standalone etc (sifus,do correct me if I'm wrong ek)..d most important one wld b d fueling..proper setting of this will give u gains s well s reliability..Of coz also depends on ur budget..forge pistons eg. cp,je brands r some well known n proven ones..
Hadi17
145
10
518
Johor
thanks a thousand times bro !! u were so helpful :proud:
xtremeleo
3,247
464
get a 20g, get it tuned on a loaded dyno, i highly suggest joshua thiran of millennium motorsport, u can use ur existing setup, well mostly.. get a higher capacity pump, boost it up, pm for more details
Hadi17
145
10
518
Johor
sure !! thanks bro !! :driver:
fazidk
413
D sifu has spoken:adore:
Hello... i'm got 1 big problem with my WIRAEVO3. My car only at car park for about 2 years coz i'm not around. After 2 years come back then kenot start. All of Power Distribution tested to my friend SATRIAEVO3, same engine. ECU, Distributor, Power Transistor, Spark Plug+cable+Coil. Starter funtion normally, but no spark from plug cable.
If got any sugestion to dis prob. pm me. Thank U bery mac.
