Evo 3 Gear Box Issue. Help..!
eldims
15
Johor Bahru
The Car : Perdana
The Engine : Evo 3
The synchronizer on my gb for 5th and reverse gear is totally screwed. the premature symptom was that the 5th gear disengages when accelerator is released while driving. now even the reverse gear wont engage at times. engaging the reverse gear becomes more of a luck. i have a VR4 gb ready but i need some help from the sifus on the options i have.
Question 1:
i heard before that a VR4 gb can be mounted nicely on to an evo 3 engine. is this true..? and if so, will i require a new set of drive shaft or will the old drive shaft could still be used..?
Question 2:
i have done some research on the VR4 gb and read somewhere that it is actually an exact same gb as the evo 3 with different ratios. if such is the case and my problem with my current gb is only the synchronizers, would it be possible for me to salvage parts of the VR4 gb (specifically the synchronizer) and use it to fix my current gb..?
the next question that comes to mind is if its even worth to repair my current gb instead of just getting another. but i like my gb though since its lsd 1.5 way. just that i wonder if its gonna get screwed again in a year or two. any info on this matter is highly appreciated. thanks.
jinkl
4,623
376
3,183
erm need to see wht vr4 gb u r using
yes it would be ok to take the synchros n gears from the 5th n reverse
if u like diffrent final drive, u r welcome to take the vr4 one also for sure
if u want to get another evo gb also its ok , u can transfer the lsd to the new box
eldims
15
Johor Bahru
For swapping in the VR4 gb, will i need different sets of drive shaft..? i think its VR4 RS. and i also heard tht VR4 ratio is a bit of a slow starter. Poor me..
Hi guys..
I'm looking for a used car for weekend travel from KL to Muar. It will only carry me alone without any other loads. I'm staying in KL but doing partime at Muar. Currently I'm using motorcycle to travel.
My target is a 1.5 or 1.6cc cars, affordable price (below 13K), reliable and not costly in maintenance.
Any suggestion of honda, Toyota or Nissan? Or should i just go for Kelisa?
FYI, I'm 177cm of height, that's why Kelisa would be the last choice.
Thanks for taking your...
