Engine Valve Loose and Shaky: Please help
arwynkumardjokovic
Sep 3, 2012
5
Selangor
hi guys please help!
After removing the engine head,i realised one of the valve is shaky.Meaning even after tightening it,it has a little freeplay...and this can cause lost of compression and kncking...my mechanic told me that the head needs to be changed...Is there any other way?
I hav a whataspp video in my handphone but dunno how to upload liao..
thx guys:adore:
dking91
121
11
518
pekan
Not very clear how the valve loose..it still loose even with valve spring on? Valve seat problem?
Sent from my Redmi Note 2 using Tapatalk
Yup, if loose will make louder noise (tappets) but valve springs should hold them in place for compression......
need to change valve guide...
that could becomes worst when valve floating and snapped....in the end major overhauls including replacing piston and conrod and bearings maybe
dking91
121
11
518
pekan
Sifus alrdy answered the question...what ur pomen said true so btter change head...cheaper then changing valve seat or send to engineering see if can just repair the valve seat
I guess it sorta depends on what sort of head this is. If it's super stock then changing a newer one (halfcut) would cost the same as sending to a machine shop to fix the seat. But if it's already ported and polished, it's probably more worthwhile machining it.
Similar threads   Forum
Car Modification
  Similar Threads
Car Modification
At about 4.00am this morning, I was awakened by my alarm sounding. Icon on my radiostar showed a break-in. I peeked outside and there it was, a GTi right beside my car, outside my parents house in Kelana Jaya. He looked at me before speeding off. I went outside to investigate. He left a still burning cigarette on the ground.
I could not disable the blaring alarm. Captor called several times and I returned call to report the attempt.
The passenger side door assembly was broken and...
