engine rebore and fuel pressure regulator
upontheriversky
275
82
hi,
i recently rebored from 72mm to 74mm piston, this increase in displacement would i need adjustable fuel pressure regulator? and still using stock fuel pump
and if i do, do i have to custom a return line? whats return line for is anyway?
thanks
SkYwAlKeR
10,139
300
ePoh ~ malacca
need or not depends on ur AF mixture... get a wideband sensor to check..
all fuel line has a return line... if not, ur fuel injectors will receive maximum pressure from the fuel pump.... fuel pressure regulator is there to regulate the amount of fuel going back into the return line, hence increasing or decreasing the fuel pressure in ur fuel rail....
upontheriversky
275
82
thanks, but how do i go and do wideband sensor test? any tips on interpreting the reading?
A Wideband sensor will tell you if you are running rich or lean. If rich then you gotta lessen the fuel intake and if lean you gotta increase. Quite straightforward la.
upontheriversky
275
82
ah ok and use fpr to regulate for rich or lean condition..i get it.
my mechanic modded my fuel line, he added an extra fuel filter near 5" to the fuel rail, he said its good coz fuel pump produce carbon in the long run and its not being filtered by filter underneath it in the tank. he said the pressure wont drop by extra filter, i just wonder if its true
do you know any place can do wideband test? i want to do compression test too..both wet and dry to see if i have broken in the engine properly
There's no real "wideband test" I think. You need to buy a AFR wideband meter and see it real time.
Putting anything in the way of the fuel pump to the injectors will change the pressure la. What car do you drive? How come your car doesn't originally have a fuel filter?
Compression test you need to do at those workshops with the tools. Most Sunway performance shops have this or alternatively check with your mech
upontheriversky
275
82
is the wideband meter comes together when u buy fpr? i saw on the marketplace, it comes with the gauge and adaptor, is that it?
i drive kelisa, initially it already has fuel filter. it sited before fuel pump. so my mech installed another one after the pump before fuel rail in engine bay
sunway got? then ill drive and ask around for price
Uh... why the heck did you mech add another fuel filter right after the pump? That's just unnecessary imho.
The wideband AFR (air fuel ratio) meter is separate from the AFPR (adjustable fuel pressure regulator). Two totally different non-related items here.
nyantong
192
50
Actually not all engines have return line. More advanced engines deploy variable fuel pump rate to regulate pressure.
upontheriversky
275
82
i know myvi doesnt have return line so usually have to custom right? if want to install fuel regulator
So this is a Myvi we're talking about? You need to mod the fuel line to include a return hose. I personally don't find a need to do this for my super stock car. Otherwise I'd post a DIY :biggrin:
upontheriversky
275
82
its actually kelisa :D im not sure got return line or not but i dont see any line going out from the fuel rail.
some ppl recommend me check a/f ratio after rebore, so after check then see if i need to install or not. i also think its not necessary but no harm checking
Aug 8, 2011
my myvi i just changed the fuel pump to walbro 255lph, and sard fuel regulator, i noticed this 2 parts is imitation/taiwan made but claimed by accs shop this is original.
Anyhow i dont create any fuel return on my fuel rail, i can modi the fuel rail,but the return hose im not sure where to put it :p
most mech will dig a hole at tank? lol.
btw by changing this 2 parts,i noticed my car went lighter and more pickup. No need to press even half pedal.
me2kimi
717
276
1,563
Puchong
I think myvi fuel regulator located inside fuel tank. Fuel are regulated inside fuel tank, therefore no fuel return line at fuel rail
Been reading a lot on car being hijacked nowadays :Not_Impressed: It made me thinking how in the h*ll did those hijacker did it. Tow from behind or front or put on towing wheels? :confused_smile:
If we pull handbrake and turn-steering lock will it help, how about parked with the rear outward??. I know there is no way to stop those buggers but at least we can DETER them. Any advise on how to deter car kena hijacked?
