WTS:-
HKS engine oils are developed with an idea of that oil is a tuning part to maximize performance of the engine. The unique viscosity categorization will effect at the molecular level on boundary lubrication. Optimized oil viscosity selection solves hydrodynamic lubrication. Airtightness and friction are highly balanced.
Engine building specialist at HKS now offers 100% synthetic special blend oil.
Benefit of using HKS Engine Oil:-
- 100% Synthetic Oil High Shear Stability;
- Able to penetrate piston oil line during engine operation to reduce friction thus allowing smooth engine movement;
- Seal up the gas leakage from the combustion chamber to maintain good compression;
- Complete absorption and dissipation to cool the engine and prevent it from overheating;
- To eliminate combustion gas Unburned deposit that may affect the engine performance;
- Remove moisture content from during combustion that create rust and corrode the engine.
SUPER RACING 10W35 is Recommended for Stock Engines - Lightly & Modified Tuning in N/A & Turbo Applications. With a good Cold Weight of 10W this gives ample protection.35 Hot weight running at Average Oil temp of 90c becomes a 40 Weight.
Recommended/Best to use for vehicles, which specified oil is W30, etc;
- 4G63 RB20 RB25 RB26 CA18 SR20 3SGE 4AGE 2JZ 1JZ VQ35 VQ25 B16 B18 K20 K24 BP EJ20 EJ25, WRX EVO SKYLINE 180SX 200SX GTR TYPE R V-TECH Sti GT4
Applicable for stock specified W30 Grade;
Shall there is any inquiry do feel free to contact us at:
016.964.5648
Thanks For Viewing & 0-100 Admin For This Ad Approval.
