Thanks.good info bro for all ecu user out there its time to get a new ecu hoho lucky me use carb but still thinking want to convert it into injection thou...
Well at least now you will know wat to look out for....when you upgrade.
Tq
Bro..Hi E-Tech,
Can you PM me the charges to replace the components? I do open my ECU regularly to check, just preparing in case i have the need to replace them.
Thanks.
Mine is a P30.Bro..
Which ecu do you have? Tq
---------- Post added at 12:55 AM ---------- Previous post was at 12:52 AM ----------
P/s: spoilt then send for repair will be more expensive.
Before spoilt, send will be cheaper-- preventive maintenances...
Mine is a P30.
But if there is no mark, still send for preventive maintenance? Is it a best practice to change all of them since it'll last another 10 years??
O shit.. i afraid i facing this problem~~~ T_T
no wonder my car got morning sick at start and idle problem..
changed few distributor, cable, plug oso same..
cleaned throttle body oso same..
checked fuel relay, pump.. more..
now the last thing i suspect now is ECU... tonight i open up and see.
e-tech , i think i throw it away d............ so sorry.........
Everything will be alrite dude coz it is a new car......
Ahlim and all....Here is 4 pic i took inside my ECU.. i never see inside my ECU b4. So i dunno is it problem or not..
Picasa Web Albums - ahlim13 - Civic EG#
Others place caps seems ok.. but look at the third pic. upper left capasitor area. Is it the problem u said.
hope can solve this cb problem T_T now sometime i start car like carburetor engine. >.<
Good.. u so pro.Nice bro....
I like the white model....
Congrats...........!
---------- Post added at 11:11 PM ---------- Previous post was at 11:08 PM ----------
Ahlim and all....
This is his ecu picture.
Confrimed, caps have leaked!
Need to be replace before more trouble comes up.!!!
2 choice... send for repairs or buy another ecu...
U decide wat you need to do....Thanks
---------- Post added at 11:15 PM ---------- Previous post was at 11:11 PM ----------
Ahlim....
Yes 3 picture, that 2 caps area looks worst but other also have leak, but very little and have no cause damage to outter areas so you might think it is ok, but actuall the cb caps are already leaking...
The biggest cap, it's the guy that will cause smoooooooooooking... TQ
P/s: that area of the connectors are related to TPS(throttel position)/MAP(air preassure) and more to the center IAT(air temp)... so i guess that is way you have cold start trouble now....but another few weeks, it will be worst unitl CEL up and cannot start.
Good.. u so pro.
Ok.. now i know whats the problem. thanks.
so what do u suggest? replace all caps or only area in pic three?
Bro,guys,
just an idea came out my mind..
can we change the caps or mod into solida-state caps??
refer to this -> TechBrief: Gigabyte Adopts Solid Polymer Capacitors For Motherboards - PCSTATS.com
SmallAPEX....i'll check mine today.scared la
---------- Post added at 11:51 AM ---------- Previous post was at 11:44 AM ----------
bro e-tech,if we change the caps,do we need to tune the ecu back..sorry.noob here
