DIY-Rear Side marker
ghostz32
742
Hye everyone
Anybody know how to DIY rear bumper side marker installation step by step..please share ya
Tq
DanzEterna
15,911
3,371
www.primeperdanaclub.com
steps.
1.measure the hole by holding the side marker frame & trace around it.
2.put masking tape around it.
3.use a cutter to cut the hole.
4.fit the frame into the hole, try not to cut too big. incase u need to adjust it later.
5.get any wires from your old lights or anywhere u can find.
6.hook it up to your rear lights.
Without lights? Double sided tape.
With lights, buy led strip, tap to brake wires. And also some common sense.
Done.
Wahsehhh.. ever since your footwell LED lighting DIY you become very action hor? :biggrin:
ghostz32 : You need some basic electrical knowledge. Do you know how to test which wire is the live brake light? If you do then tap from there and connect to your blingbling
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Weiii, don't say like that. Just telling only.
Common sense is a must.
Saying it doesn't mean i action leh.
idnawse
205
36
perak
not tap to brake lamp wire but dawn light/lampu ujan/lampu kecik (what so ever they call) wires. So the marker will light up together when u switch it on ..not when u brake. :smokin::smokin:
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
rear fog lamp you say? Hmm, plug out the cable of the brake light. Should ve located in a boot, switch on the lights, then try to use multimeter and see, which one makes the needle jump to 12v or below, then that is the one.
Wires should be given right? Just switch off the lights.
Splice the wire, long long spliced will be better. until u can see the copper/iron wires in it.
Poke it in to the hole u tested out. Then tape it around so that u can still poke in to the socket. And rmbr to tape the expose metal wires. To prevent electric shocks or blowing fuses.
Then carefully plug it in. The above post should be better. More advanced sifu.
I don't suggest u splicing the ori brake wires because i think thats harder to determine and abit messy, and also if new car, MIGHT void warranty.
Hope u understand
cheers.
ghostz32
742
Thanx for info guys..i'll try and post the results soon..
ghostz32
742
Time constrain..i'll try make it this month..if posible :shot:
Dear bros...
Yesterday I've swapped my rims to waja first edition rims.....after balancing and alignment and also adding a spacer for the rear wheel because it seem the offset is to inside kena absober.....so after that when i drive....nice but once i apply brake...i can feel vibration from the brake......why ar?? is it the rear spacer make it like that ar...previously....using 8holes rims also no problem like that and with spacer at the front summore....sigh....anyone installed waja rims...
